My open udder observations......
Started by Gus Duc, July 02, 2009, 02:17:19 PM
Gus Duc
I'm sure you could...... I noticed that my Arrow baffles fit nicely in the udder with no pipes but you would need to make some straight tips or weld them into place.
I'm toying with the idea of plugging the bottom outlet on the udder & running one cored OEM can or possibly a custom piece with a larger diameter pipe & can.  If it comes out nice, I'll take it off & have it Jet Hot coated silver.
tilt
I also run my s2r 1k with the open udder and just recently had my 6k service, and the guys at my dealship got bored and wanted to see what it was showing on the dyno.  they ended up showing that it got 80.15 max power and 60.55 max torque.  they said that performance was alot better then they though it would be but that the air/fuel ration was a little high it danced right around 15 which they said that over a long period of time can cause excess wear on the engine.
MostroS2R
Quote from: tilt on July 09, 2009, 03:41:28 PM
I'm running mine with just the udder and I'm a little worried that it might be running lean. Haven't pulled the plugs but I will this weekend.
Rocco
07 S2R
DucRS
Black S4RS                               Black Multi S - Sold
Carbon Red Diavel                     ST4S abs - Sold
620 Red.
DucRS
I used the Packing and the perforated tubing from my Termi's I chopped up and created the perfect tone  [evil] and it also resulted in the right amount of back pressure so the bike doesn't run too lean.
620 Red.
ICON
Quote from: DucRS on July 10, 2009, 09:09:15 PM
It would look a lot cleaner if you used rivets instead of those exhaust brackets. My 2 cents.
DucRS
ICON, I like the rivet idea  [thumbsup]. Did you have your exhaust Ceramic or Powder coated?
620 Red.
ProTeal55
Quote from: MostroS2R on July 10, 2009, 05:43:51 AM
When I was running the Open Udder on my S2R1K I did notice a slightly lean condition.
fter installing a FATDUC I was able to get rid of all the poping on decell and the bike ran much better/stronger..
Member: Half Fast Chicago
Website:
Gus Duc
Quote from: ICON on July 10, 2009, 10:11:16 PM
How do you seal the tips when you use rivets ???  Don't they leak ???
ICON
Quote from: DucRS on July 11, 2009, 06:42:31 AM
Ceramic all the way. Powder coat will bubble up with the heat.
Go to Lowes or Homedepot for the Rivet gun....$20, rivets $7 and the drill bit too. Your bike will look even better than it already is. [thumbsup]
SwiftTone
Quote from: DucRS on July 10, 2009, 08:49:59 PM
Anyone know where I can get pipes like that?  I want to do this to my s2r100.
CookieMonster
pardon my ignorance but aren't boom tubes just nicely cut tips?
"Friend don't let friends ride stock"
-S2R1k 992 DESMO LIFE
Kopfjäger
#27
Quote from: CookieMonster on December 16, 2015, 07:54:07 AM
It's a whole system.
http://www.motocreations.com/?tag=boomtubes
CookieMonster
SwiftTone
Boomtuves still look like exhaust manifold with nice tips. I don't understand the craze
