MrI mods a fireplace
Started by Popeye the Sailor, July 03, 2009, 05:22:56 PM
So, wood stove home came with was inadequate. No control of airflow, no ash pan, not enough heat. Sucks, really. It's shown off to the right here in this picture. Yeah-the little dinky thing with the chintzy brass.
Paula and I decide to buy a new, better wood stove. We decide on a Vermont castings defiant, and contacted an installer to see what he thought, which was that it just wasn't going to fit, find something smaller. Me being stubborn, unreasonable, and rash, I decided to ignore the advice of the paid professional. After all, I didn't want something smaller-house is big, needs a fairly sizable stove.
This leaves one option, which is make the fireplace bigger.
Armed with a lifetime of no masonry experience and large volumes of liquor, I waited until P was out of town (did not want her to see potential disaster) and I picked up a nice circular saw, and a masonry blade, and set to work. The original was seven bricks tall, now it's nine.
I can't tell you how much dust this made. I mopped the house roughly six times before Paula came home to see what disaster was left. The black dog was white, the white dog looked like one of Joels legs. The horror. I also had to cut out the metal support that's there to basically hold all the bricks that are above the fireplace. After the initial cuts, I  knocked out most of the mortar with a hammer and chisel, broke the remaining bricks into pieces, and removed the bits.
I then bought some metal stock, and made a new horizontal metal support for the bricks over the fireplace, and some vertical struts to support it, and welded them in place. Then I filled the gaps between the metal struts and the bricks with concrete. Everything got coated in a nice flat black.
Today, the installer guys came in and put in my new fireplace  [thumbsup]
Now I just need it to get cold.  ;D
Looks nice, but looks like you made the hole one brick too big...
Got Duc
Quote from: NAKID on July 03, 2009, 05:28:40 PM
It's a top loader-I needs the space  ;)
Bun-bun
Looks a good bit better than I thought it would.
Ummm, you DID use a  high temp fireplace mortar around the metal, right?
Quote from: Bun-bun on July 03, 2009, 05:33:43 PM
It will never get hot enough
Porsche Monkey
+1  do it over
Got Duc
Quote from: painter on July 03, 2009, 05:34:39 PM
New tubing is double wall if I am right
Quote from: NAKID on July 03, 2009, 05:39:34 PM
That makes sense....
in never land. Why would top load something thats on fire? I burned my eyebrows off once like that. :( Maybe its just me though.
How far does it stick out? is there anyway you could uninstall it and carve out the back of the chminey? I think you should of gone with a white to reflect the heat into the house. I think it'll make a big difference. but that thing is so freaking big it probably wouldnt matter.
Looks good though especially since you had no masonry experience!
Quote from: He Man on July 03, 2009, 05:46:33 PM
Toploading a wood stove is really convenient, to be honest. I've had this same model before.
I want it to stick out-it heats the house better.
In terms of getting the heat into the house, unpainted works better than a finish, but with this, it won't matter.
A pellet stove would've been e better choice. ;)
Quote from: trouble on July 03, 2009, 05:52:25 PM
Thank you.   [laugh] [clap] [clap] [laugh] [clap] [laugh] [clap]
