February 24, 2025, 07:02:53 PM
Please Help
PDR on Gas Tank vs Body Shop .. OPINIONS?
Topic: PDR on Gas Tank vs Body Shop .. OPINIONS? (Read 1833 times)
Cucciolo
July 09, 2009, 06:00:38 PM »
Hey folks!
I have a dent on my gas tank and want to send it to a guy who does PDR. He quoted me $199.00 for labor but I have to ship it to him. I have the stock tank for the S4R with no custom job and was wondering if you think it is the most cost effective way to fix this dent this way versus taking it to a body shop that would repaint the whole thing after filling the dent. I haven't quoted a body shop yet.. thought I'd ask for opinions here first. The idea is to save money
Last Edit: July 29, 2009, 11:40:23 PM by Cucciolo
Porsche Monkey
JuddDdd likes my
The DMFer formerly known as Ducaholic
Re: PDR on Gas Tank vs Body Shop .. OPINIONS?
July 09, 2009, 06:08:15 PM »
PDR won't work. The metal is too thick. Ask your PDR guy if he has any experience with Ducati tanks.
Quote from: bobspapa on July 18, 2009, 03:40:31 PM
Bun-bun
2002 M620 Dark ie
July 09, 2009, 06:44:43 PM »
Body shop.
Rumor has it that there's this guy , he's on the forum a LOT, and he paints ducs. Now if I could just remember his avatar. . . .
Kidding aside, PDR is'nt all that P that it's built up to be, and a body shop, or Duc painter(What is that guys name. . . ?) is probably not going to be that much higher priced. Plus, it gives you more artistic freedom to make it just the way you want it.
See my "the Rat bike lives" thread in A&M for an idea of the process.
July 09, 2009, 09:23:29 PM »
Paintless dent removal can be done, depending on the damage, but usually some evidence of the damage remains. It might be worth it if you were having it done locally for a lot less money. If you want the tank fixed and repainted it needs to go to someone who does motorcycle tanks.
The guy who's name Bun-Bun can't remember can be found here:
http://www.frostysfinishes.com
Whats his name will treat the inside of your tank with POR 15 and reinforce the hinge as part of the repair.
Last Edit: July 09, 2009, 09:25:46 PM by howie
Porsche Monkey
JuddDdd likes my
July 10, 2009, 03:31:01 AM »
Quote from: howie on July 09, 2009, 09:23:29 PM
I have had two different PDR guys try my tank with two different methods. Mind you these are two of the best PDR guys in town. Neither one had any luck with my tank. Couldnt even get close. As Howie said, usually some evidence of the damage remains.
redial
July 10, 2009, 05:58:03 AM »
my local shop told me it could be done but only if the dent is totally smooth.
the dings (sharper and smaller) left inside the dent caused by the handlebar controls
would not come out with the paint in tact as they would have to put tool marks on them to get them out
quoted 120 for dent and let me paint it,
or 340 to fix all marks and repaint any color. im going to do this when i have some extra money
they even clear and sand over the logo until you cant feel it with your fingernail.
very awesome paint guys and they have experience with ducati tanks Black Walnut in central PA if anyone is nearby
Porsche Monkey
JuddDdd likes my
July 10, 2009, 08:42:44 AM »
Send it do Ducpainter. If your going to spend the money then spend it on someone who knows these tanks. Let him do the hinge repair even if its not leaking, yet. Any body shop can paint a tank, it would suck if your freshly done tank started leaking.
Cucciolo
July 10, 2009, 11:22:01 AM »
I will contact ducpainter..
Either way I will have to get the tank removed and shipped. Is this easy to do? I have to remove the fuel pump.. better off having the shop remove it ? wonder how much that would cost.
Porsche Monkey
JuddDdd likes my
July 11, 2009, 06:38:48 AM »
Your best bet would be to ask Ducpainter.
July 11, 2009, 08:30:14 AM »
Isn't the tank plastic?
Be very careful with PDR, they can very easily crack the paint and you won't see it and this will let moisture begin to attack the steel and start corrosion (rust).
July 11, 2009, 08:32:48 AM »
Quote from: Cucciolo on July 10, 2009, 11:22:01 AM
It's very easy and no need to remove the pump. Just make sure you get all the fuel out.
July 12, 2009, 03:11:45 AM »
Quote from: trouble on July 11, 2009, 08:32:48 AM
the pump
does
have to come out to braze and coat...
