Clutch fluid changing color
Started by hihhs, July 09, 2009, 09:02:37 PM
hihhs
OK. This may be a very stupid question;
I've got an M1100 with 700 miles on it. Had the first service at about 640 miles. Put on termi slip-ons, a 14t sprocket and got the mechanic to lose the charcoal canister.
Today while riding, I noticed that the clutch fluid in the reservoir looks kinda purple. Front brake fluid still looks yellow, and rear brake reservoir looks yellow with a hint of blueish purple...
WTF????  ??? ??? ???
Monster 1100
vwboomer
Mine always turns grayish/black. I figure this is the reservoir rubber deteriorating but dunno. No effect on functionality though.
2005 S4R - Sato, PM, CC, Sargeant
2005 GasGas FSE450
2004 Honda VFR
The DOT approved brake fluids are light amber colored.  This is for identification purposes.  Other colors are available, such as ATE Super Blue, which is identical to ATE Typ 200 except for color.  This could be your problem, if so, not a problem at all.
hihhs
Quote from: howie on July 09, 2009, 09:43:10 PM
Interesting and thanks for the reply but no one has added fluid...the color just changed
Monster 1100
hihhs
Quote from: vwboomer on July 09, 2009, 09:12:59 PM
I thought of that but damn, would it deteriorate so quickly??? The reservoirs have never even been opened since the dealer filled them.
And thanks for the reply!
Monster 1100
mine usually goes black within 500 miles after i bleed it....
i bleed it about every 3-4 months regardless of miles.
Porsche Monkey
#6
Clutch fluid which is the same as brake fluid turns darker with time. It is due to contaminants, anything from rubber to moisture. Brake fluid also goes through many heat cycles as in each time you ride the bike. This causes the fluid to break down. This is why its recommended to flush those fluids every year. What color is the fluid in your rear brake reservoir?  Bet its turning too. Your not hurting anything yet but just follow the service intervals and you will be fine.
hihhs
Thanks very much to all of you for the replies. I was sweatin' this. [bow_down]
Monster 1100
Bones
it ain't that new "Mood Fluid" is it?
I think purple means you're in love....
(hey its Friday and I rode in to work, I'm in a good mood)
I'm a loner, Dottie...a rebel...
Porsche Monkey
hihhs
Quote from: Bones on July 10, 2009, 07:38:37 AM
[clap] [clap] [clap]
Even my SO thought that was funny and its only like 5AM here!!!
Riding to work makes for a good day!!
Monster 1100
hihhs
I think I just found the perfect fix;
Monster 1100
erkishhorde
Quote from: hihhs on July 10, 2009, 08:27:30 AM
Yes, ignorance is bliss.  [thumbsup]
my brake fluid, i replace every 3,000 miles. its been a year since i flushed mine out, it is still clear. both my monsters ahve been like that
corndog67
My front brake is still nice and clear/yellow, but the clutch and the rear are both dark.   I suppose I could change them.   But maybe not.
