Tank questions
Started by He Man, July 10, 2009, 09:29:31 PM
I know theres a sticky, but, i jsut need to make sure since i always tend to misread stuff when im in a rush...
will a 2003 steel tank fit on an S2R 1000? The hinge should be easy, more importantly does the battery fit? seat?
what about the fuel pump power? what about the fuel intake? theres a steel 03 tank and i want to buy it fix it up and put it on my S2R1000...
Kopfjäger
no to which part? i can deal with the battery since im going pods, it will give me a lot of place to move the battery... the seat cut out is impossible for me to fix, but i can deal with the wires...so as long as the system works the same way and the motor pumps the same amount of fuel when asked by the ECU...
Ill have to wait until the normal people wake up then!
herm
a 2003 fuel injected tank will work on the s2r1000 (i have one of each)
you will need the hinge that goes with the steel tank, as well as all the internals (fuel pump, filter, fuel lines, etc...)
thanks for the info, i have to go hunt for another one. I missed the uaction cause i came home late. :(
