I think I broke something...
Started by Mr Christopher, July 11, 2009, 02:28:15 AM
Mr Christopher
Today I installed my new handlebars on my 2001 M904ie only to find that my bike now wont turn over. Everything from the bars removed and reconnected OK - or so I thought. But I must have jarred something loose. Can someone point me in the direction of what to check first?
When I turn the key I no longer hear the whir of the fuel pump priming, and when I hit the started button nothing happens - I dont even hear the click of the starter motor. Power to the rest of the bike seems fine.  I only touched the handlebar mountings, can anyone help me please?
Thanks
Chris
Check the kill switch on the right handlebar.
gage
A.duc.H.duc.
Quote from: painter on July 11, 2009, 03:40:50 AM
+1
I can tell you most of us have done that before. Doh!
teddy037.2
but the kill switch doesn't prevent the pump from priming...
EEL
I'm putting money on the clutch interlock.
Mr Christopher
Thanks guys, but the kill switch was the first thing I checked (OK yes it was switched to off [bang] but that wasn't the cause of my problem). I had to loosen the ignition assembly to slide it off and I wonder if I pulled a wire loose?
EEL, what is the clutch interlock?
Also I suspect the fuel pump must be a clue as to what I've broken. I'm going to try and find some wiring diagrams.
teddy037.2
the clutch interlock switch is under your clutch master, the switch closes when you pull the lever in.
it's a safety thing, like the kickstand switch
Quote from: teddy037.2 on July 11, 2009, 01:20:58 PM
does too.... ;D
bobwithboobs
Quote from: teddy037.2 on July 11, 2009, 02:54:33 PM
i HATE that kickstand switch.. i want to remove it but i dont know if its healthy to have it running with that heavy lean the ducati gets when the kickstand is on...
minnesotamonster
Quote from: bobwithboobs on July 13, 2009, 03:16:38 AM
huh?
I don't think there will be any problem with your bike running while leaned over. That would kind of defeat the purpose of riding the twistys  ;)
A lot of people bypass that switch. Pretty common mod. You can do it yourself if you're handy, but if you're not you can just use this   http://www.monsterparts.com/pc/80024_01/Electrical/80024_01.html
2004 S4R
1998 Honda F3 (Track)
2001 M600 (Now the Wife's)
Quote from: teddy037.2 on July 13, 2009, 09:14:57 AM
then my bike is freaky
...or I'm wrong...
or we're both right and the kill switch kills fuel on some models and ignition on others.
teddy037.2
Quote from: painter on July 13, 2009, 01:34:00 PM
...or I'm wrong. ;D
...but you're never wrong.
and maybe teddy likes to ride the freaky
:D
teddy037.2
...or I'm wrong...
fine, make with the edits!  [drink]
