Longer kick stand ... 848 kickstand on monster ...
Started by cyclops, July 14, 2009, 04:05:22 AM
cyclops
Anybody know where I could find a kick stand about an inch longer than stock for an 06 S2R1000 ? I raised the rear a bit and now it leans a whole lot ... I just have a bad feeling about it...
If you try to push it over, you'll see that it takes a lot. Not very likely to tip over.
Nevertheless, MotoCreations have something coming - don't know when.
Kopfjäger
Dannog
Oncycles still have some cyclecat kick stands that are 1" longer than oem
http://www.oncycles.com/browse.asp?page=1&department=billetaccessories
Pretty sure those aren't for S*R bikes. Single/double lip issues IIRC.
cyclops
Well i just found another solution .. Im using my 848 kickstand on my monster . Its not that much longer, maybe 1/4"  , but i think the angle is a lil different . I put it on and now the monster sits at a better angle, and i like the wider bottom better also, wont sink in pavement as easy ...
Kopfjäger
Quote from: cyclops on July 18, 2009, 09:09:41 AMand i like the wider bottom better also, wont sink in pavement as easy ...
You can always just find an empty beer/soda can, flatten it and put it under your stand to keep it from sinking.
cyclops
Quote from: kopfjager on July 18, 2009, 09:20:16 AM
I cud , but its so much easier not having to  [moto] ... now i can just park and not worry about it, unless its like 100 degrees out ...
