For the lazy people
Started by erkishhorde, July 14, 2009, 07:06:06 PM
erkishhorde
Speed bleeders!
http://www.summitracing.com/parts/RUS-639560/
My dad got these for his car which makes more sense since the brake pedal and the bleeder screw are so much farther apart. But if you're really lazy you could use them on your bike too.
Kopfjäger
I'm not lazy, I's just tired all the time.
vwboomer
I'm not lazy, I'm energy efficient.
Seen these but never got round to buying them. Would be nice on the truck.
2005 S4R - Sato, PM, CC, Sargeant
2005 GasGas FSE450
2004 Honda VFR
redial
dont you need to use the pedal with the car on in cars with ABS to get the fluid to push through the abs module?
hypurone
Quote from: redial on July 15, 2009, 04:58:24 AM
Nope, and you had better NOT try that with an "integral" ABS system or you're gonna get hurt!
teddy037.2
I'm not lazy, I'm with the government!
hihhs
it isn't laziness it's an economy of motion
Monster 1100
DucHead
Spiegler has offered these for quite a while.   :)
eah, those Russels have been around for quite a while. Put them on my 96 240SX back in 98-99...
zarn02
Quote from: hypurone on July 15, 2009, 05:55:24 AM
Satisfy my curiosity, and cure my ignorance: why is this?
hypurone
Quote from: zarn02 on July 16, 2009, 08:53:16 AM
An "integral" ABS system supplies the braking assist power, normally supplied by a vacuum booster, via a pump that creates an average of 1500psi. Sometimes more depending on the mfg'er. If you don't follow specific procedure and bleed this pressure off and you crack open a bleeder or component, or re-pressure the system while still working on it, things get nasty and painful, quick!
