February 04, 2025, 10:04:45 PM
Napoleon Baren problem
Topic: Napoleon Baren problem (Read 3312 times)
moto-zen
July 14, 2009, 06:25:12 PM »
'98 Monster 900. Is the internal diameter on the handle bars smaller than normal? The "universal fit" Napoleon mirrors will not fit.
(Is nothing on these bikes straight forward?
) As always, any ideas are appreciated. As is any criticism for not seeing the obvious.
The democracy will cease to exist when you
take away from those who are willing to work and
give to those who are not. - Thomas Jefferson
erkishhorde
Re: Napoleon Baren problem
July 14, 2009, 08:58:11 PM »
Yeah, the m900s have the aluminum bars that have a smaller inner diameter than most bars. You can try drilling out the bars but it requires a really big bit. I forgot what size I used but it helps a lot if you have a drill press too.
Someone else might chime in with other suggestions but that's what I found.
psycledelic
July 15, 2009, 01:19:36 AM »
I believe I would try to take stock of the mirror inserts before I drilled out the bar. I assume that the mirrors work on opposing wedges. I would think that the handlebar is a certain thickness by design. Drilling it out might make it weaker.
Just my .02
06 S2R800 - the wife
04 999s - the mistress
moto-zen
July 15, 2009, 04:28:40 AM »
I did think about drilling at first. I guess now would be a good time to get a nice black handle bar. I mean, I really do need it to use my mirrors. And I do need my mirrors to drive...so, I guess I'll should do the responsible thing and purchase one today. [off to rizoma] [moto]
g-force
09 M1100s Pearl
July 15, 2009, 05:43:58 AM »
Rizomas might have the smaller inner diameter also.
I had the same problem and solved it with a trip to the hardware store. There is a tab on the metal part of the mirror that goes into the bar that may need to be filed down, then you need some rubber tubing, a bolt and a flange nut.
-G
moto-zen
July 15, 2009, 07:36:26 AM »
Quote from: g-force on July 15, 2009, 05:43:58 AM
-G
Thanks for the heads-up!
Online
July 15, 2009, 10:12:57 AM »
Trim down the rubber inserts and either buy new nuts or grind down the flanges on the old nuts.
In short, make the mirrors fit the bar, not the other way around.
moto-zen
July 15, 2009, 10:40:39 AM »
Great advice all! Thanks for the extra set of eyes, I didn't think about modding the mirrors.
Grrrly
Industrial Grrrl
July 15, 2009, 04:31:39 PM »
I've had the same problem with my CycleCat bars.
I replaced the rubber piece with a piece of fuel line, and a nut with out the flange and voila.
Like Howie said, don't modify the bars, modify the mirror.
The Evil Twins:
Urban Assault Vehicle:
2002 Duc M 6/900 Industrial Edition
Track Weapons:
2004 Suzuki SV650
2009 Kawi ZX-6R Monster Edition
Privateer
July 19, 2009, 06:56:42 AM »
kind of related. I bent the big machine screw that holds the mirror arm to the bar insert. Anyone know what type of screw it is so I could replace it? I can't seem to find the right one at the hardware store (found a nut that works, but not the matching screw).
Privateer
August 04, 2009, 06:45:56 AM »
Quote from: Privateer on July 19, 2009, 06:56:42 AM
for reference, 8x1.25 30mm socket head cap screw, stainless steel.
Nick gave me a line on a REAL hardware store. Dug around a little and found what I needed and bought some spares in stainless and mild steel.
