February 24, 2025, 07:55:15 PM *
News: Please Help
Author Topic: 696 Ehaust Sound Change?  (Read 2108 times)
DucatiTorrey
My wife's super hero is my
Industrial Designer
« on: July 16, 2009, 08:21:14 AM »
I have a 696 with termis, DB killers removed. love it. anyways, we've talked about it on here before, how we love to decel and let the engine pop and rattle and scare the shi& out of people. It's wonderful fun.
But my question is this. Does yours still have the same thunder after about 3000 miles? Mine seems to have settled down a bit, no more popping (well, a little, but a severe drop) and rattling, back firing when i engine break anymore. its kind of worrying me. The shop here said its just everything is working in sinc now, and is all broken in. If that's the case, i liked th sound way more when it was brand spankin new.
anyone else? Broken in wrong? i thought i followed the rules.
on a side note, i had a bad oil filter from ducati (didn't know they made them, unless i was fed BS) took two visits and  days to figure out where the leak was coming from
anyone else here?
  - real place
minnesotamonster
« Reply #1 on: July 16, 2009, 08:26:17 AM »
Backfiring and popping on decel, isn't generally a good thing. Be glad it has cleared up.  waytogo
2004 S4R
1998 Honda F3 (Track)
2001 M600 (Now the Wife's)
DucatiTorrey
Industrial Designer
« Reply #2 on: July 16, 2009, 08:29:58 AM »
well, it wasn't a problem thing i guess, it was that split second i think there was slack in the chain maybe? anyways, just added rumble i guess you could call it
thanks though for the reply
  - real place
Omnipotent Potentate
Personal Pretext
« Reply #3 on: July 16, 2009, 10:25:04 AM »
Popping like is a common symptom of a leak in an exhaust connection  - so it sounds like you might have had one that cured itself
ArguZ
« Reply #4 on: July 16, 2009, 11:03:06 AM »
You could fire a shotgun while riding..
Or drag a sledge hammer behind you for sparks
That would also give a nice rumble when breaking hard, maybe even popping something  laughingdp
No seriously, its good its gone...people will not throw beer cans after you in the morning and you system will last longer.
tristantumble
« Reply #5 on: July 16, 2009, 12:01:00 PM »
i have a 695 with the same setup, and after awhile i felt like it didn't sound as mean as it first did. After some deliberation i realized that i had just  gotten used to it.
07.695 (sold)
07. sport 1000 biposto
« Reply #6 on: July 16, 2009, 10:40:09 PM »
i kinda noticed the difference. i mean i really have to chop the throttle to hear the pop. (when coming into a town after a few kilometers sprint)
i figured the motor is smoothing out with use. not a problem for me.
DucatiTorrey
Industrial Designer
« Reply #7 on: July 20, 2009, 05:28:48 PM »
agreed, thanks guys (and gals?)
its probably a good thing, as long its not me going def...
  - real place
DoubleEagle
« Reply #8 on: July 20, 2009, 08:36:17 PM »
My S4Rs is as raucous now as it was when I had the full Termis installed along w, an Open Air Box 3,000 miles ago.
The 1098 R has the Full on Race Termis and it still after 3941 miles sounds like it did when it was new.
At a certain RPM  in 2nd gear it sounds like several hammers beating the inside of a 50 gallon drum. Most noticeable when going through small towns at about 25 mph.
No Backfiring.
If I don't have my Earplugs sealed in my ears when riding either of the 2 bikes I can't take the sound. It's loud but not Harley drag pipe loud. No noise killers in either.
I don't set off car alarms like I used to w, the Harleys and the Vance & Hines Long Shots w,out Baffles.
Dolph       Smiley
mstevens
Monsterless
No Monster of my own, but my wife has an '09 696
« Reply #9 on: July 21, 2009, 12:22:53 PM »
You left out "at 2 in the morning."
Mad Duc
Just because it is wrinkled doesn't mean you should call it a
« Reply #10 on: July 21, 2009, 04:22:49 PM »
I'm at just under 3k, with about 2500 on the termi's and mine is as loud as it was before, pops & everything else. I love it, very hooliganish.  High RPM's & Off throttle are the best noise they make.
PA's official Ducati Owner's Club: PennDesmo.org
ducleaner
« Reply #11 on: July 22, 2009, 09:15:54 AM »
the word you guys are looking for is "overrun" and it's perfectly fine for the engine to sound nasty on overrun. It's actually a function of fuel mapping (that's why pure race engines do it more than street engines) and silencers. If you remove the baffles, install aggressive pipes, or anything that exposes more engine noise - you will hear some. If it's truly changing on non-changing set of exhaust, then it's probably driving habits or fuel mapping. Most modern ECUs are adaptive. If the Monster's ECU is adaptive, then it will run more tame if you ride more tame. The other side of that is even at a given set of fuel mapping, the way you come off throttle and go into overrun will affect how much of that sound you get.
DucatiTorrey
Industrial Designer
« Reply #12 on: July 22, 2009, 09:35:38 AM »
i find this "overrun" happens more if the bike hasn't been driven in a couple days too. Also, its more "tame" and a jaunt on some slab. this is interesting though, i wonder if it is adapting to my city riding, etc...  i do more around town riding i guess. then get on it hard in the country.
it has the Termi ecu btw, anyone know if it is adaptive?
  - real place
