downshift-clutch out-downshift-clutch out - stall......
Started by tangueroHondo, May 20, 2008, 11:09:23 PM
tangueroHondo
Equipment:
05 S2r / 3.5k mi on clock / Motul 20W50 in the crankcase / new Iridium plugs / Acid yellow tank and cowl / a few scratches here and there / full tank of fuel / starts, idles and runs perfectly.
Scneario:
Engine oil at about 200F.  Coming up to a stop - downshift to 3rd - clutch out - rpms fall off - downshift to 2nd - clutch out - rpms fall off - downshift to 1st - stalls.  Not every time, not most times, just some times.
Why?
If the stalling only happens when downshifting to first you may have a problem with clutch drag, in other words, incomplete clutch release.  Does the bike also want to move forward in first with the clutch disengaged?
tangueroHondo
#2
When cold, yes.  I've read numerous other posts where this is the case, so i figured this was the nature of the S2r beast.  maybe  let out the clutch lever pin, where it contacts the master?  I bled it about three months ago.
