DP Front Fender (CF) Question
Started by LSD4me, July 30, 2009, 10:32:44 AM
LSD4me
Hi all!
Has anybody installed the DP CF Front Fender for the M696? I got it in yesterday and mounted it no problem but then took it out and noticed right away that the front forks rub up against the fender when they are compressed (Bump)...I looked and i did see that the fender is awfully close to the forks and there isnt room for adjustment...the holes on the fender allow just enough room for the bolts to go through...
Has anybody else had this issue?
2009 M696
DucSteve
i just installed mine on my S2R. i noticed it was a bit close, i had to make sure the bands that go along the fork where you attach the fender and flush and straight
Spencer
Where did you get the fender because the one you have pictured is not the DP CF front for the 696.
It is the "Diversion style" generic fit DP CF fender
The real 696 DP CF Fender is an exact copy of the stocker and fits the same.
pennyrobber
Often the multi fit parts take a little tweeking to fit just right on a particular model. If you have already tried adjusting you might need to shave the part a bit in the area that interferes with the forks. The more you mod the more you find out that "bolt on" is more of a idealization than an actual description. Definitely double check though before you start cutting into your brand new carbon fiber bits.
LSD4me
So wait....The DP Diversion Style CF Fender is NOT a Ducati Performance part or is it...Is it just a Ducati Perfomance  Generic fit? Do they offer a different one that is a CF duplicate of the original?
2009 M696
Spencer
The "Diversion Style" CF front fender from DP has been around for a while and is a "multi fit" or generic fit item from DP.  It is not the specific DP CF front fender made for the M696 or M1100.  That would be:
Part # 96991109B Ducati Monster 696/1100 Carbon Front Fender
And is the one pictured in my post above.  It is a perfect copy of the new style stock fender in CF
The one you show in the 1st post is for the previous set of monsters.  That's why you might be having some issues
Quote from: LSD4me on July 30, 2009, 12:27:10 PM
It is a Ducati Perfomance part - though other make ones that looks the same - it's just not for the 696.  The one that Spencer posted is for the 696.
LSD4me
2009 M696
pennyrobber
Don't get too discouraged yet. Motowheels through one on to their project 696. You might want to shoot them a PM (see sponsors section) to see how they handled the issue you are having.
Quote from: ronin1 on August 01, 2008, 11:14:33 PM
Someone mentioned we should put one of these on...
Diversion Fender
LSD4me
So here's the million dollar question....The DP CF Diversion Front Fender (Generic) runs for $250 and the DP CF Front Fender for the 696 (MADE FOR 696) runs for $199....Is the one made for the 696 a DP part or made by somebody else...it seems as though the one made specifically for the 696 has alot more CF than the diversion...Just a thought
On a side note, i contacted motowheels, (where i purchased it) and they said for me to get a file and bore out the holes a bit so that i can slide if forward a bit and then tighten..makes sense but i was weary about filing away at the CF...anybody want to chime in?
2009 M696
Spencer
#10
From Ducati the DP CF front fender for the 696/1100 retails for $293.65
The same style knock off (not that there is anything wrong with it) CF fender from MotoWheels is $199
Although I learned my lesson regarding "cheap" CF, it's usually cheaper for a reason
This very thin and warped POS from a major supplier was of course returned
Personally, if I paid $250 for a fender I wouldn't be taking a file to it then have to worry about it
shifting and damaging my forks. But that's just me  ;D
LSD4me
So just to recap and to verify i understand correctly...
The Ducati Fender made for the 696 from motowheels for $199 is NOT A DP PART..? Correct?
The Ducati Fender DP Diversion (Generic) for ~$250 IS A DP PART? Correct?
And if i understand correctly, the Generic DP Diversion fender is NOT enough protection for the front end? I dont mind filing it down a bit as it wont destroy anything but before i go on damaging a part that i can return right now, i want to make 100% sure that it will suit my purposes well and that is NOT a CHEAP CF part...I dont ride much on gravel so i would hope it would provide enough protection on daily street rides....
2009 M696
Spencer
You need to look at what you ordered and what was sent
Motowheels lists three CF front fenders for the 696
A non DP stock version :  $209.00 Mfg. Part No.: MD-MN08-C01
a DP Diversion : $265.00 Mfg. Part No.: 96948800B
and a non DP Diversion : $249.00 Mfg. Part No.: MD-MN00-C01
As far as slider protection from the Diversion style fender, I prefer more protection from dirt, sand, bugs, rocks thrown up by cars.  A chipped slider can get real expensive DAMHIK.  But hey, some ride without any fender or fork protection at all.  I'm more of a function over form kinda guy  ;D
LSD4me
I got the DP Diversion ~$265...
Well at least its a DP part and is not a cheapo CF part...
As far as dirt and stuff, im pretty good about cleaning it....I will def have to watch out for scratches and if tey start appearing, im putting a more protective one on for sure..
THANKS for all your input!!! [drink]
2009 M696
LSD4me
#14
So the drama continues...After banging my head against the wall with why this is not fitting correctly, i matched up the part numbers from what i ordered and what i got and sure enough, the part that motowheels sent me was MD-MN00-C01 which is NOT the DP part...
I called them up (and they were quite nice) and i explained to them that i received the wrong part and they said that its actucally the same exact part and that the part i got (the wrong one) is BETTER than the DP one and the only difference is that the DP part comes in a box that says ducati...  ??? ??? Kind of like buying a Maserati and getting a saturn and being told well they both have wheels and they both transport you back and forth and the saturn gets better gas mileage so..... [roll]
They explained that the DP part will have the same fitting issues as this one and I told them that i would like to get the part that i paid for...Is that too much to ask..??? [bang]
Now to the question....Is the quality of the non DP part better/worse/same as the DP one...
2009 M696
