February 07, 2025, 09:18:38 PM
Ducati MOB
The Doorbell
Topic: The Doorbell (Read 5449 times)
velocess
The Doorbell
August 01, 2009, 07:06:22 AM »
In the last 6m I've witnessed three Ducati owners start their bikes without pulling in the clutch. Am I missing something here? I thought using the clutch took a strain off of the starter motor. The part that kills me is the use of the index finger. Yes, much like activating a doorbell, these folks are extending their index finger and I think I saw one of these "1/2 a man" lift his left foot at the same time.
Vindingo
02' 620 Dirty
Re: The Doorbell
August 01, 2009, 07:28:20 AM »
If the bike is in neutral you don't need to pull in the clutch.
Index finger usage is in the secret manual, guess you didn't get the memo. Using your thumb is just so pedestrian.
It's a Ducati, show some friggin' class
Last Edit: August 01, 2009, 07:30:20 AM by Vindingo
For $50 you can touch my
Re: The Doorbell
August 01, 2009, 07:54:31 AM »
Quote from: Vindingo on August 01, 2009, 07:28:20 AM
That and it's way harder to keep your pinky extended.
mostrobelle
Re: The Doorbell
August 01, 2009, 08:15:49 AM »
I have a special pair of white gloves that I don for the occasion. I keep them in a little lace-lined basket that hangs off the clip-ons.
94,500 miles...05/22/15
Spidey
Crashin' mofo
Re: The Doorbell
August 01, 2009, 10:05:05 AM »
How gauche! We don't discuss such things in mixed company, you peasant.
remy
Re: The Doorbell
August 01, 2009, 10:16:17 AM »
I normally stomp on my starter with boots as if I were turning the engine over myself.
ROBsS4R
No matter where you go, there you are
Re: The Doorbell
August 02, 2009, 01:08:12 AM »
The only time I use the clutch to start the bike is when I am walking it while its running. basically maneuvering the bike underpower while I am not on it.
I normally just start it in Neutral and let it warm up for a while.
My Photo Site
http://secondnature.smugmug.com/
ducnymph
Re: The Doorbell
August 02, 2009, 01:56:39 AM »
I must have trust issues with the neutral light because I always pull my clutch lever in when starting my bike! I've had my bikes jump from not actually being in neutral in the past
Maybe it was an old beater thing and I haven't stopped that habit even though I've moved on to newer bikes.
I'm a thumber on the starter all the way. The pointer just wouldn't feel right
Ex: 09 monster 696 pearl white
Current: 05 Yamaha R6
ducati_tim
Semper ubi sub ubi
Re: The Doorbell
August 02, 2009, 03:09:59 AM »
I engage the clutch every time I start the bike. Many years ago I had parked in front of a bar, and when I returned and went to start it up the bike lurched forward and fell to the ground.
I heard from a friend that someone had been sitting on the bike. Maybe they had knocked it into first; maybe I had forgot to put it in neutral (unlikely but possible); who knows? After that, I feel it is better safe than sorry and engage the clutch before starting.
'Rispetta le donne!' Italian Spiderman
duqette
Does this bike make my butt look fast?
Re: The Doorbell
August 02, 2009, 05:21:19 AM »
Quote from: ducnymph on August 02, 2009, 01:56:39 AM
I'll see your trust issues and raise you to compulsive. I check for the neutral light, then gently rock the bike back and forth a bit just to make sure it's really in neutral, and
then
I also pull in the clutch lever. You know, just in case....
Index finger? How gauche. I use a special ivory implement. From Italy. Carved by virgin Italian nuns. At dawn.
"Youth is wasted on the young." --GB Shaw
petemg
Re: The Doorbell
August 02, 2009, 07:59:41 AM »
why do you have to leave
Re: The Doorbell
August 02, 2009, 10:00:36 AM »
Quote from: petemg on August 02, 2009, 07:59:41 AM
why can't I quit you
Desmostro
alis volat propriis
Re: The Doorbell
August 02, 2009, 02:54:38 PM »
Amen. (That's +1 for you heathens. )
Once a bike slips out of neutral and ghostrides across the parking lot crashing into a wall when you hit the start button with your nose picking finger, you may want to start it with the clutch pulled in as well as the brake lever while sitting on it like you have a pair and intend to ride. punks.
Michael Moore
Testa di cazzo
WebGeeK
Re: The Doorbell
August 02, 2009, 03:05:44 PM »
Well, since my neutral light is busted and stays on all the time, if I don't pull in the clutch I've got a good chance of getting launched, or at least having my footpegs surgically implanted into the backs of my calves.
La nuova moto e il vecchio motociclista :: 2000 Monster 900 (il vecchio) :: 2008 Vespa GTS (doppio) :: 2010 Streetfighter S ("il PastaBusa")
remy
Re: The Doorbell
Reply #14 on:
August 02, 2009, 06:53:01 PM »
Quote from: Michael Moore on August 02, 2009, 03:05:44 PM
This is on the Streetfighter, right?
