Rivet-type master links
Started by ScottRNelson, August 01, 2009, 11:24:10 AM
ScottRNelson
I have an RK chain tool that allows me to remove many (but not all) chains without cutting them - by pressing out a pin.  It then has other attachments for pressing the side plate back on and for expanding the rivet to get a secure fit.  I've installed at least half a dozen chains during the few years that I've owned the tool and it has always been a real bother to get the side plates the exact distance apart.  Too loose and the O-rings/X-rings won't seal properly - too tight and the joint will be stiff and the O-rings/X-rings will wear out too soon.
So when I've installed a rivet-type master link I've always measured carefully and been a bit apprehensive about getting the exact fit.  I was wondering if there was a way to make some little metal spacers to help out with this.
Well, last week I had to buy a new chain in a hurry, so I got an EK Quadra-X SRX X-ring chain from Cycle Gear and didn't realize until too late that it only came with a clip-type master link.  I put that on, but didn't ride the bike much (since I don't trust clip master links on the highway), then ordered a matching rivet-type master link from Cycle Gear.
When I went to install the new master link this morning I had the pleasant surprise that it came with a set of spacers to get the exact distance when installing the new master link.  It was so much nicer installing this link, because I just slid the two spacers into place then pressed the plate on until it was tight, and finally expanded out the two rivets until I got a bit of resistance.  The spacers didn't exactly just fall out afterwards, but they weren't that hard to get back out of there.  And now I know that this master link is installed exactly the right way.
One of the spacers with the master link:
The two spacers installed:
CairnsDuc
Or you could a lazy prick like me and get a EK Chain with Screw link, do up the nuts until they won't move, snap off the lugs, put on O rings, Job done and the Crowd goes wild  ;D
corndog67
That's a pretty good idea.  I put  a DID press/rivet link on the S4 a couple of weeks ago and was wondering about squeezing the links in too tight, so I measured the width of the standard link across the plates outboard of the pins and made the rivet link the same.
Bigbore4
All of the links I have installed had machined shoulders to control spacing.  Press the side play down to contact, rivet and done.  No bother.
I generally use RK chains and links.
Dave
96 M900         05 FJR         86 SRX6
And a brand new Super Tenere coming in no one knows
scott_araujo
Quote from: corndog67 on August 02, 2009, 07:57:19 AM
Yup, that's the way to do it.  The only annoying part is you have to press a little, remove press, measure, not far enough, press a little more, lather, rinse, repeat.  Anyone have a better way to do this without going too far?
Scott
ScottRNelson
Quote from: scott_araujo on August 05, 2009, 01:37:51 PM
Yes, put the little spacers in like I was originally talking about.  It's so much easier than the squeeze and measure approach and you know when you're done that it's the perfect distance.
Did you notice what I said in the first post?
scott_araujo
Scott, totally, but when I got my DID chain with master link it didn't come with spacers.  Do you know somewhere I can get them separately?  I'm guessing they should be manufacturer specific and since they get squished they'd only be good for a few uses before they get trashed.
Scott
ScottRNelson
Quote from: scott_araujo on August 05, 2009, 03:34:46 PM
Cycle Gear can order you a master link for an EK 520 SRX chain and you can get a set that way.  And I can't imagine them getting worn enough to make a difference even after using them for hundreds of chains.  You would think that other O-ring and X-ring chains would need different spacers, but they're just right for the RK chain on my 888 and also just right for whatever chain came on my XR650L.
I would like to find alternate sources for such a useful little tool.
you can also get the DID chain tool that will auto stop, thus making life 10x easier.
LA
I never even thought about it.  I always use DID and a DID chain tool. I do it the way the destructions say.
I grew up on shaft drives, but have been riding Ducatis since 1979. I'm still not sure I'm doing the chain stuff correctly.  I change em out at about 15,000 miles as a rule.  For the first time I put a new chain on old sprockets that look just like they did when new so far as I could tell - it's a black art to me. ???
LA
scott_araujo
I have the less expensive DID look-alike chain tool with no set stop.  Oh well, not like I do it all that often.
Thanks,
Scott
Quote from: scott_araujo on August 05, 2009, 10:15:48 PM
Thanks,
Scott
the $20 one? thats the one im talking about, xpt it does have a set stop. maybe they updated it?
scott_araujo
Maybe it does and I was somehow using it wrong.  Or maybe I've got an older model without the stop.  I went to far and then had to take it apart again and re-press it.  I'll try to remember next time and see if there is a stop.
Scott
if its the same, the stop is automatic (cant turn it on or off). Maybe you used the wrong side, though i dont think the tool allows that. im not sure.
corndog67
Scott
To be perfectly honest, I use 2 big pairs of vice grips and work the side plate on.   It isn't the fastest way to do it, but it is effective.
