Just for the Record !
Started by DoubleEagle, August 02, 2009, 04:09:24 AM
ODrides
I've hit the "rev limiter" while in 3rd or 4th on my 998 at the track -- same engine as the S4Rs.  I was worried the first time.  It's not a pleasant experience, but the engine doesn't seem to mind.  With the limiter kicking in around 10500 rpm it's pretty easy to let the bike wind up too high.  The fast guys on the Japanese bikes ride the whole straight boucing off the rev limiter.  It sounds like an angry giant tapping out morse code.
Kopfjäger
#31
Quote from: DoubleEagle on August 04, 2009, 06:51:58 PM
No matter how slow you take to get there ?
No momentum will influence the outcome ?
Dolph      :)
Nope, at least not in the lower gears. You'll hit the rev limiter at the same speed everytime...
Quote from: NAKID on August 05, 2009, 04:35:13 AM
Unless you take into account road surface, rider position etc etc etc.  ;D
DoubleEagle
Quote from: ODrides on August 04, 2009, 09:36:07 PM
Generally , as fast as the " R " accelerates,  (and I think the Tach is hard to read at a glance ), especially if the Sun is shining at you, I'm just going w, the RED shift light since you can't miss that even if you are looking at the road.
Dolph      :)
DoubleEagle
Quote from: kopfjager on August 04, 2009, 09:44:20 PM
Did someone say rev limiter?
Ducati 900SS Turbo Drag
Ducati Monster S4R Arrow pipes rev limiter v2
Man, that 1st one sounded like someone was dropping ball bearings in the engine one at a time !
Nasty ......................!
Dolph     :)
