January 02, 2025, 08:47:53 PM *
Author Topic: New to forum need advice plz.  (Read 3251 times)
dansamp
« on: May 21, 2008, 02:18:50 PM »
Hello all,
just joined up here found this site through speedzilla
anyway I have a 98 M900 (the motor with the small valves)
I have a set of 95 SS900 heads and am wondering if they are a direct bolt on
my concern is regarding the oil passages  since the 95 SS motor has external oil lines to the cylinders and the 98 motor has internal oiling passages
Dan............. drink
« Reply #1 on: May 21, 2008, 02:29:01 PM »
Hello all,
Calling some one that knows..... Grin
Good question.
Juan
« Reply #2 on: May 21, 2008, 02:35:45 PM »
Well come to the DMF Summary..
Sorry I don't know   Grin  But maybe Stuart can..  "Duck-Stew"
Here is a link..
www.flightcycles.com
« Reply #3 on: May 21, 2008, 02:48:00 PM »
Here is a link..
...or ducvet might have some real insight.
dansamp
« Reply #4 on: May 23, 2008, 06:33:19 AM »
Bump ........
anyone Huh?Huh?Huh?Huh?Huh?Huh??
 Roll Eyes
oppet
« Reply #5 on: May 23, 2008, 07:30:00 AM »
I Think that you need leftside cover from earlier model where those hoses go and the hoses of course. they are return lines as far as I know.
Others may confirm perhaps, Im not 100% sure
« Last Edit: May 23, 2008, 07:33:04 AM by oppet » Logged
« Reply #6 on: May 23, 2008, 08:16:36 AM »
I pinged Duck-Stew.
I'll eventually be facing this issue with my Cagiva, so, that makes two of us that need to know.
dansamp
« Reply #7 on: May 23, 2008, 08:20:33 AM »
the oil lines go from the crankcase to the cylinders
my concern is with the oiling to the heads
there are no external lines to the heads in either early or late 900 motors
so I am  hoping the oil passages from the cylinders to the heads is the same
that is my question
Dan...........
« Reply #8 on: May 23, 2008, 08:32:40 AM »
It's a bolt-on swap.
The '98 M900's w/the 'W' heads had different oil drain-backs than previous engines (the external lines) they drained back the oil down through the barrel into the crank-case.  The older engines had the oil drain-back hoses external to the alternator side cover.
dansamp
« Reply #9 on: May 23, 2008, 10:36:10 AM »
Xlnt !!!!!  waytogo
so it looks like I have my work cut out for me
now I have to decide if I should tackle it myself  coffee
it would be a good learning experience  bang head
thanks for the info
wish me luck ...........
Dan.
« Reply #10 on: May 24, 2008, 03:41:34 AM »
Hey Stew, did the 900 motors have the same change from square tooth to round tooth belts around '98 or '99 like the 750s did? Part of that "bolt on" might be swapping the cam pulleys over...
big
« Reply #11 on: May 24, 2008, 08:15:41 AM »
big
IIRC Big, the 900's were always round tooth belts...
