February 04, 2025, 10:09:55 PM *
Author Topic: Routing 02 sensor with aftermarket exhaust?  (Read 1396 times)
WhiteStripe
Monster Addiction
« on: August 04, 2009, 06:39:00 PM »
Have a full Arrow system on stock ECU (FatDuc) so i am keepnig the 02 sensor.
Just curious how others may have routed the 02 wires.  Without the FatDuc i don't think it would have reached, but honestly it was getting late and i kind of half assed it.
Just don't like the way it comes over the swing arm and has to dangle down from end of sensor.
Any thoughts?
2006 S2R 1000, Arrow CF exhaust, FatDuc 02, CF open cc with stock pp
Mike_D
« Reply #1 on: August 04, 2009, 11:47:39 PM »
I have the exact same set-up as you on an 08 S2R1K.  I ran the O2 sensor line up and away from the back pipe on the right side of the rear shock and along the right side of the trellis frame where it then connects to the FatDuc.  This works great because it allows easy access for adjustments as it tucks in the space between the two cylinders.  Hope this helps.
2008 S2R 1k.  Black.  Pazzo Levers, 14 t front sprocket, CRG Hindsight LS mirrors, Cycle Cat Frame Sliders,  Oberon open clutch cover and gold/black EVR pressure plate, full Arrow exhaust with reflashed and mapped ECU, tail chop with gold Rizoma Avio 21 turn signals, Ohlins rear shock and Rizoma fluid reservoirs.
kumabull
« Reply #2 on: August 05, 2009, 03:11:26 AM »
I agree with above comment exactly how I did it  chug
2007 Ducati S4RS
Apex Clip-ons
Rizoma Signals
Rizoma Grips
CRG Shorty's
MP's Dual HeadLight
Speedy Moto Pressure Plate
Speedy Moto Clutch Cover
Cox Oil\Rad guards
Ordered: Arrow Full race exhaust Carbon Cans
CompWerks Chop
Integrated Tail Light
SpeedyMoto Black water pump cover
Gus Duc
« Reply #3 on: August 05, 2009, 12:52:05 PM »
+2............. up the right side...... way more slack & much easier to hide waytogo
How's she running with the Arrows & the Fatduc Huh?
WhiteStripe
Monster Addiction
« Reply #4 on: August 09, 2009, 08:49:02 AM »
Thanks.  I had the FatDuc running to the left and in my rush didn;t realize i could pass it trhough over to the right up front.  Need to clean this up.  The way its running now is pretty half-ass.
Gus - been meaning to email you to say thanks!  The bike is running good on the Arrows with the FatDuc.  Installation was a breeze, sorry i asked so many questions up front, i appreciate your help.
Was getting a little more popping on decel then i liked at the same FatDuc setting as the stock pipes.  Richened it up to jsut a little shy of 3:00 and it is running great.  Smells a little rich at idle, but the tips are staying pretty clean.  Will pull the plugs in a couple of weeks to check that out.
I am commuting most days on this bike so i may tackle the DB killers next - just seems like a bit of a project.  Right now just enjoying being obnoxiously loud Evil
kumabull
« Reply #5 on: August 10, 2009, 07:55:21 AM »
I actually had my bike in the shop over the weekend for plastic tank replacement. The bike was acting up and stalling the whole way there. DucPond hooked it up for some tuning. They actually wound up removing the FatDuc all together and Im still running about 4% to rich. really weird but they got her all sorted out and she runs like a dream now.
now I have to figure out the diameter of the coolant line from the water pump to the hard line mine has a seeping issue Sad
2007 Ducati S4RS
Apex Clip-ons
Rizoma Signals
Rizoma Grips
CRG Shorty's
MP's Dual HeadLight
Cox Oil\Rad guards
CompWerks Chop
