Gas tank cap
Started by bondibox, May 21, 2008, 06:54:22 PM
bondibox
My gas tank is rusted shut - can't turn the key.  I'll probably need a new tank, since I drained a lot of rustwater out of the old one (I'm considering buying a clean, dented tank, which pains me to no end).  My first option would be a replacement keyless racing gas cap, but I'd like to clean up the old locking cap & key assembly and put it in the new tank.  Anyone got an idea on how I can get the old cap to open in order to remove it, short of cutting the tank in half?  Is it best to not use the old tank anymore or can I try and clean it out and possibly coat it?
Quote from: bondibox on May 21, 2008, 06:54:22 PM
I'd sacrifice the cap and save the tank.
Not too many that can't be saved.
You might try some WD 40 on the cap.
teddy037.2
+1
just remove the old cap. I had used this... marine epoxy stuff to seal the tank from future rust on my old GS500... local moto shop did it for me.
once the cap's off, you could try and clean it out from the underside if it's just sticky
Monstermash
If you're really concerned about having a keyed fuel cap just buy another one on Ebay and bring it to your local locksmith and have it rekeyed. I bought one and it cost about $15 at the locksmith.
bondibox
Thanks for the responses, but "just remove the old cap" is much easier said than done.  I like the idea of sacrificing the old cap and re-keying a new one, but it's still frozen shut.  I've removed the 5 screws which hold the cap in place, but until I turn the key and open the cap, it's still in locked and shut position.  Sure, I tried WD40 into the keyhole, even removed the tank and angled it so that the drips would travel toward the latch, but it's been a couple of weeks and that key just isn't going to turn.  Maybe I could drill it out?
Quote from: bondibox on May 22, 2008, 05:38:08 AM
The cap won't come off because there is a security screw underneath.
Did you try tapping on the cylinder to shock it?
Sometimes downward pressure will take the load off the mechanism and make the key easier to turn.
If all else fails...drilling is the answer.
Jobu
Quote from: ducpainter on May 22, 2008, 05:42:08 AM
Yea.  I had to open mine with a drill.  But that was because I'm a dipshit and lost the key.
You can also try the WD-40 or PB Blaster in the lock, let it sit for a while. Then take the key, and insert and remove several times wiping it in between...
