*Show Me Your Clutch Cover & Pressure Plate*
Started by JoDuc, May 21, 2008, 07:22:30 PM
Desert Dust
I want to replace my stock springs with the Speedy Moto springs and caps.
Are  there any tutorials about this? It can't be as simple as just removing the old and putting in the new.
Torque settings?
Loctite?
07 S2R 1K:  "You are not special. You're not a beautiful and unique snowflake. You're the same decaying organic matter as everything else. We're all part of the same compost heap. We're all singing, all dancing crap of the world.”
FIFO
#211
Quote from: Desert Dust on April 20, 2010, 08:41:33 PM
Torque settings?
Loctite?
Sure is that simple.
If you not changing the pressure plate do one at a time.
One off one on. 7 Nm /5 ft lb
Or if you change the pressure plate tighten the bolts in a cross pattern
No loctite required the spring presure keeps every thing in place. [thumbsup]
http://ducatimonsterforum.org/index.php?topic=11240.30
Note, 5 ft lbs does not require a torque wrench. Its just a smidge more than handtight. Don't go Hercules on those suckers lest you want a snapped hub post.
Desert Dust
Quote from: Rob s on April 20, 2010, 10:34:08 PM
Thanks for the help.  :( ;D I'm just going for springs and caps for now, so I'll use the one-off at a time method.   [thumbsup]
ctrain
Bikes I've jumped and/or crashed:
84 Kawasaki KDX 80 - Bike i learned to ride on when I was young(er)
84 Kawasaki KDX 200 - First naked bike. crashed so frequently the plastics wouldnt stay on.
99 KTM 620 - If you could even get the thing kick started in the first place...
02 Yamaha Zuma - not a motorcycle but still crashed and jumped it way too many times.
04 Harley Road King Classic - Awesome story behind this
06 Ducati S2R 1000 - neither.... yet.
Desert Dust
OK, so now I have my open clutch cover, but what do I do when I give her a good wash? Do I cover the clutch up with plastic wrap? I can't imagine that water would be good for the clutch. I never ride in the rain here in SO CAL, but I'm sure some of you open clutch fans have?  Any advice?  ???
Water won't hurt anything. As soon as you turn it on, the heat and motion will get any water out.
Desert Dust
Sounds good! So I should probably ride for a spell right after the wash instead of parking it?
dbran1949
Quote from: Desert Dust on May 07, 2010, 03:33:50 PM
Yes just carry something to wipe the housing. I usually take a disposable towel. After just a few blocks I shut the bike down. All the water spits out all over the open cover, usually laden with crud from inside the clutch housing. Wipe it off and yer good to go
Desert Dust
I ride in the rain with the open cover too. Its no big deal. If you were to shut it off immediately after soaking it, the worst that could happen would be light surface rust that would be broken free as soon as you turned it back on.
I would advise against getting it soaked, and then letting it sit for a year or more... [thumbsup]
BellissiMoto
STM Hi-Flow clutch cover with DucaBike slipper clutch:
Rob13
Here's my set up Desmo Porsche pressure plate and a MPL type-1 clutch cover.
Amlethae
EVR "Cart Before the Horse" Edition with SpeedyMoto 7-spoke cover.
WANT @ AMLETHAE
Heres mine. I bought it out of necessity. though it looks pretty make the beast with two backsing sweet.
Kukuri Gold, with Woodcraft clutch cover w/ double thick steel skidpad.
