Anybody repacked their Termi cans?
Started by invisible monster, August 11, 2009, 06:59:19 PM
invisible monster
Would like to repack my side by side Termis on the S2R.  Have found some references to a Termi repack kit but cannot find it for sale.  Has anyone done this?  My exhaust has lost that smooth Termi sound.  I have the cf cans.
2010 KTM 690 Enduro R
2008 Buell Ulysses XT
2003 Yamaha WR250F
1972 Yamaha 175 CT2
you don't need a repack kit from Termi, you can use ANY repack stuff
I repacked my Sparks cans using stainless gauze I got off Ebay.  Came out to about $10 per can and about $3 for the rivets.
Stock, they use fibreglass, but that always burns over time.  Stainless gauze doesn't burn, ever, will take 10 years to rot.  It is NOT as quiet though.
old packing:
new packing ( 5 or 6 layers of stainless)
jc whitney has repack kits for motorcycles at about $20 bucks a pop. they are fiberglass.
invisible monster
Thanks for the replies.  I'm guessing that this is the procedure, let me know if I am incorrect:
1 - Drill out rivets that hold outlet cover onto exhaust can
2 - Remove old packing material
3 - Insert new packing material
4 - Rivet outlet cover back onto can
I am interested in keeping the volume down somewhat so I'll most likely go with the non-stainless packing.
2003 Yamaha WR250F
1972 Yamaha 175 CT2
Quote from: invisible monster on August 12, 2009, 05:56:55 PM
2.5 -  Curse and pregnant dog about the weird ash that comes out on your hands and sofa if you try it indoors
3.5   Curse, pregnant dog and moan about how hard it is to slide back into the can.
one tip.  in order to get the repacked core back in, you will need to compress the packing.  there are several ways to do it, but all involve some hassle.
the best way (for me) is to get some shipping wrap paper, the thin brown stuff and roll a single layer around the packing -- get it TIGHT -- and then tape it with some paper masking tape.
slide the whole thing in and leave the paper/tape in.  if you are really crafty, you can put an extra piece of tape on and pull it off AFTER it's all inside the tube (hard to describe) so you take the tension off the packing.
the paper and tape will cook off over time.  hence the ash when you open a can with fibreglass!
Ddan
Ducati Monster Forum at
www.ducatimonsterforum.org
invisible monster
Thanks for the tips.  I'm going to order some packing and give it a go.  Will probably do it in my garage though, seeing that it doesn't work the best in the living room!
2003 Yamaha WR250F
1972 Yamaha 175 CT2
The Architect
Has anyone been able to successfully dismantle Termi cans and repack them?
I'm repacking the CF Termi cans on my ST.  I've drilled out the rivets and removed the forward (pipe side) cap.  The rear cap is extremely difficult to remove.  Does the cap separate from the inner perforated pipe?  Does anyone have any experience or advice?
Ddan
On the Sils, the perforated tube was attached to the lower cap. The CF sleeve should pull off the cap once the rivets are drilled, I wonder if they used some RTV or something to seal the cap.  Could you have a burr or piece of rivet stuck in the hole after you drilled them out?
The Architect
Quote from: Dan on April 28, 2010, 01:33:51 AM
I doubt RTV was used and for that reason I'm not going to use it either.
I do think I burred the stainless end cap but I can't even get it to budge.  What are the chances of burring all six holes?
I'm wondering if the bracket side mount interior nuts are preventing any movement?
The Architect
So I got the end cap off.  Thanks to the RTV, it wasn't an easy task.  Good call Dan.
I found the cans contain two chambers!  And I can't get the CF cover off!  Arrrggggg!
2 Wheel Wanderer
Donno if this will help but here are some pics from when I cut down my termis.
http://www.facebook.com/album.php?aid=165765&id=219140114873
The Architect
Quote from: 2 Wheel Wanderer on April 28, 2010, 07:11:32 PM
I appriciate the pics.  What you had is exactly what I was expecting to find but I didn't.  I think I've resolved it.  I just have to grind down some welds.  Once apart I'll post some pics.
The Architect
I hope I'm not thread jacking but I new topic for the same issue might be a waste?
So I think I found the reason why I can't pull the inner perforated pipe out of the outer sleeve.  Typical cans have straps to hold them in place.  These cans have to threaded nuts in them which is what the bracket connect to.
Anyone have any idea how to pull the nuts out so I can get the inner core out?
booger
Those are threadserts and they're permanent.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
