February 07, 2025, 04:08:26 AM
Where to relocate the coil?
Topic: Where to relocate the coil? (Read 2321 times)
theducatikid
August 15, 2009, 09:30:52 AM »
So I'd like to lose the side panels. I've seen a bunch of bikes here w/o them and really like the look. What I'm wondering is where to relocate the coil for the vertical cylinder (it's hidden behind the left side panel). I'm curious where some of you have put it or just some suggestions from the mod gurus. Thanks!
DarkStaR
Re: Where to relocate the coil?
August 15, 2009, 11:30:21 AM »
What year and model?
So: '05 620
If you have the later smaller square coil, it doesn't look too bad as is.
If you have the older big round coil, the easiest place to put it is under the seat.
It's a tight fit as is, your wires will be a bit on the short side, the oil breather catch will be in the way, and you'll need to figure out a way to mount it.
Easiest way would be to buy or make a plate to remover the oil catch, and relocate the regulator/rectifier.
Last Edit: August 15, 2009, 11:38:16 AM by DarkStaR
herm
August 15, 2009, 07:22:08 PM »
+1 for under the seat on that model.
El Matador
Do I need knee pucks for my
August 15, 2009, 07:43:01 PM »
theducatikid
August 16, 2009, 03:51:55 PM »
Well after much debate as to wether or not to ditch the crankcase breather catch, I decided to do it. Thanks for the replies.
sejman
December 23, 2010, 03:44:03 PM »
Yes, yes I know it's been along time since the last post, but did a search and found the exact topic here and wondering, what (if anything) did you guys do with the original mounting bracket? Seems like a shame after carefully hiding wiring and coil that the bracket should remain as is...
Feral 859
December 23, 2010, 04:06:26 PM »
Quote from: sejman on December 23, 2010, 03:44:03 PM
Ground mine off and repainted the area.
December 23, 2010, 04:46:18 PM »
Quote from: theducatikid on August 16, 2009, 03:51:55 PM
i find myself putting my bike closer and closer back to stock. My breather box spits out a ton of oil its annoying as hell.
atomic410
steel horse i ride
December 27, 2010, 12:10:56 PM »
did you just take the hose off or put on a mini k&n. I have the mini k&n on my race bike and really don't have much more than a wipe worth after every weekend of running the s&&t out of the bike.
Team Atomic Racing Check us out @
www.teamatomicracing.com
Thanks to my 2011 sponsors;
Motorex, Vortex Racing, Sidi Racing, Studio 299, Dunlop, Motoprimo, Caztek, On Track 4 Him, Fix Studio
2009 Framstad Cup winner
2009, 10, & 11 CRA 5 hour endurance race winner
CRA Expert #2
ZARS track school instructor
