MS Access - Passwording Question
Started by Monster Dave, August 19, 2009, 10:47:42 AM
Monster Dave
Hey everyone,
I'm trying to secure a password field in an ACCESS table. I've set the input mask to be a password, however as an administration how does one gain access to passwords protected by the input mask?
Thanks!
cyrus buelton
1999 M750 (joint ownership)
2004 S4r (mineeee)
cyrus buelton
Quote from: Monster Dave on August 19, 2009, 12:47:20 PM
Anyone?
Ok, so I am about to leave work so I should answer as I won't look at this thread again until i am drunk, stoned, and methed out.
The input mask should just show up on the forms and not in the table try to put the input mask in the form field and see if it shows up in the table as just the password.
2004 S4r (mineeee)
cyrus buelton
I just tested it out and that is the case.
Put the input mask on the form. The password will be visible in the table if the table column is set to text without an input mask.
2004 S4r (mineeee)
Monster Dave
Quote from: cyrus buelton on August 19, 2009, 12:56:55 PM
Interesting, that was the first thing that I did and was unable to view the PW in the table.....
cyrus buelton
Quote from: Monster Dave on August 19, 2009, 01:33:15 PM
I just tried it on a blank database and it worked fine.
that is really odd.
2004 S4r (mineeee)
Monster Dave
Quote from: cyrus buelton on August 19, 2009, 01:57:24 PM
that is really odd.
I figured it out this morning while retracing my steps/attempts from yesterday. Essentially I had done what you had suggested before I posted the question, but I had set the input mask to "password" on the table not realizing that the field in the form would have to be set independantly.
It was sort of a Homer "d'Oh!" this morning when I realized it. Sometimes you just can't see the forest through the trees!!
Thanks for the help!
Dave.
cyrus buelton
glad I could help you out.
I suspected you made a "mistake" while doing the input and after re-tracing a few times, you picked up the error.
I do it all the time too.
2004 S4r (mineeee)
