Oil Cooler (a different approach)
Started by pennyrobber, August 19, 2009, 11:15:20 AM
Demoni
I believe they have 2 oil temp sensors, one on the filter screen that goes to the inst cluster and another that goes to the ECU to adjust fueling or something like that. I know there is an oil sensor and an air temp sensor that feed directly to the ecu and the ecu uses these numbers to calculate the temp differential.
99' Ducati 900SS (yet it's not a monster...yet)
pennyrobber
#31
After some rethinking, I fabbed some new brackets for the oil cooler. I give you version 2. It came out much cleaner this time but I still need to source a Mulitstrada valve cover to finish the job.
DucHead
Triple J
Quote from: Mr. Exact on August 24, 2009, 06:18:57 AM
Oil temp sensor on my DS is attached to the Oil Drain plug...
Quote from: ducatiz on August 24, 2009, 06:24:13 AM
i believe it is the TDC sensor, but don't hold me to that.  oil temp is in the oil strainer plug.
Oil temp sensor on the DS motor is on the oil cooler...at least it is on the Multi and Hyper motors. I don't have any sensors on the drain plug.
Triple J
Quote from: pennyrobber on October 05, 2009, 08:40:15 PM
PM sent.  [thumbsup]
rockaduc
Looks better than version 1.0.  Very nice!!  [thumbsup]
Quote from: Triple J on October 06, 2009, 09:20:15 AM
Must just be on the Multi and Hyper. Mine is in the same location as the one on my 800...
Not the drain plug, the oil intake strainer plug on the side.  I can see it in the pics above.
Triple J
#40
Quote from: ducatiz on October 06, 2009, 01:37:32 PM
Is that the plug to the left and above the oil fill cap, right next to the clutch cover? I have no idea what that is. All I know is that the temp sensor is on the oil cooler...maybe there are 2 temp sensors??
I'll have a look at my shop manual when I get home.
You know where the oil screen is right? It's on the cover for that screen on my S2R1000....
Triple J
Weird...my DS1000 motor doesn't have anything near the oil screen.
Just looked at my Multi workshop manual...on the Multi (and Hyper since that's the oil cooler I have) the sensor to the left of the oil fill plug measures oil pressure. Oil temp. is measured at the oil cooler like I thought. There aren't any other oil temp. measurement points.
Quote from: Triple J on October 06, 2009, 05:02:47 PM
MTS 1100 has it on the bottom of the cooler
Monster DS has it on the oil intake screen plug.  You are looking in the wrong place either way, that oil pressure bung is on the cover.  The temp thermistor is on the case, bottom-right.
you guys with your newer monsters and all your fancy 'lectrics. pfffff.
