February 04, 2025, 10:49:46 PM
one tooth less on front sprocket?
Topic: one tooth less on front sprocket? (Read 2452 times)
09/1100
August 20, 2009, 04:08:20 AM »
can anyone tell me what i can expect from putting a smaller front sprocket on my monster 1100? what do i do about speedometer calibration? by the way the speedometer seems to be about 8 percent off at 65 MPH even with stock sprocket. anyone else notice this?
Re: one tooth less on front sprocket?
August 20, 2009, 04:16:19 AM »
the bike will pull better and be easier to ride at slow speeds...less clutch slipping.
The speedo reads off the rear wheel. No correction is necessary.
All Duc speedos have been optimistic by roughly 10%.....forever. Don't know why.
numbskull
'07 S2R1000
August 20, 2009, 08:39:49 AM »
There are two drawbacks, both minor. You'll lose some top end speed and the front sprocket may wear a little more than a 15T. To counter the wear, it's better to increase the rear sprocket by 3 teeth.
thruxton
2007 S4Rs
August 20, 2009, 06:31:21 PM »
Quote from: ducpainter on August 20, 2009, 04:16:19 AM
the "your speed is" signals always put me spot on
