Will's Thread
Started by WillS, August 23, 2009, 12:06:58 AM
Xerxes1769
#136
Will,
I ended up buying the S2R1000 fuel pump...(since it was the newest and less mileage one)
http://cgi.ebay.com/ebaymotors/DUCATI-08-MONSTER-S2R-1000-OEM-GAS-FUEL-PUMP-PUMPS_W0QQitemZ190357647144QQcmdZViewItemQQptZMotorcycles_Parts_Accessories?hash=item2c52332f28
should be here hopefully by the end of this week, I put the fuel pump/flange I had ordered from you guys on hold just in case this pump doesn't work.  As it turns out the Ducati factory is on a month long vacation and my pump was going to take a lot longer than I was previously told.  So hopefully this will work and I can get the bike out sometime soon.
Also bought some new brake/clutch reservoirs and was hoping you guys could install them...they should be here end of this week...
for clutch and brake
and for rear brake
Your bike has the coffin masters right?
Xerxes1769
Yes Sir!  Coffin style and fugly as all hell!  Don't tell me they will not fit!?!
Well, those are a one piece design.  The reservoir is permanently attached to the master cylinder if I am not mistaken...
Xerxes1769
Dang!  Now to see if I can switch the three reservoirs for something else...
WillS
yes, the pump...good
the brake and clutch stuff, nope, no worky,
let us know when you get the pump
Xerxes1769
Will,
Dropped off the pump and got a look at the bike...the clip-ons look fantastic!  Hopefully pump will fit and work and I can get the bike back soon.
Xerxes1769
Will,
Bike's running great so thanks!
WillS
no, no need to thank, thank you
yes, yes need to thank.  you thanked.
WillS
RUFKM
Aloha Will,
Bringing the S4RS in for safety check Friday and change the front rotors/pads to stop the jurging.  Dropped off new BrakeTech rotors with Shawn when I made the appointment.  The rub is there's a little caution note on the installation sheet that says the stock bolt shoulders may not fit the rotor hubs.  I want to go new bolts anyhoo so I'm hoping you could maybe check the fit before Friday so if there's a problem maybe it can be addressed before the appointment.
Mark
WillS
ok, i'll take a look tomorrow
see ya on fri
