November 23, 2024, 10:23:11 PM
Please Help
Desmotropic
Will's Thread
6
7
8
9
29
Topic: Will's Thread (Read 86339 times)
Xerxes1769
2012 Ducati 1199 Tri 1975 Yamaha YZ125
Re: Will's Thread
Reply #90 on:
December 02, 2009, 06:04:14 PM »
Long time reader....first time poster.....So I just happened to read the plastic tank forum and went outside to check my bike (2007 695D) and noticed that my tank is warped/expanded...Would you guys happen to know if SS covers this under the 5 year emissions warranty or not?
WillS
Re: Will's Thread
Reply #91 on:
December 03, 2009, 08:13:12 PM »
come on by and let us run it by ducati.
it is up to them and not south seas.
hope that helps.
Xerxes1769
Re: Will's Thread
Reply #92 on:
December 03, 2009, 08:31:45 PM »
Awesome! Will take it down to SS on Saturday, should I make an appointment or just show up? BTW thanks for your quick response!
WillS
Re: Will's Thread
Reply #93 on:
December 03, 2009, 10:45:15 PM »
no problem
just come down with your bike so shawn can see it and get all the info.
hadesducati848
your sisters love my
1998 R1 (sold) 2009 848
Re: Will's Thread
Reply #94 on:
December 12, 2009, 05:24:22 PM »
Will i was wondering if there are any down sides to removing the baffle plate (i think that is what they are called) on my stock mufflers.i read that it will help reduce the heat under the seat a lil bit and it will also help the engine breath a bit better. plus it will also make the bike sound throatier. i know termis are the way to go but mods that cost money are on hold for a while. the arrows in the pic are pointing to what i am referring too in case baffles are not what they are called. so any input would be greatly appreciated. thanks.
Re: Will's Thread
Reply #95 on:
December 12, 2009, 08:35:56 PM »
If those stock cans are anything like the ones from my old S2R (and I believe they are) then there is a lot more than just removing a plate. My old cans had a "three chamber" gas routing system that had the exhaust gasses going back and forth through the cans at different directions. You can core them out (do a search for exhaust coring), but you will need a drimel, a few hours, a couple of friends and several beers.
teddy037.2
Re: Will's Thread
Reply #96 on:
December 12, 2009, 10:16:52 PM »
for enough beer, i'm willing to take a dremel to just about anything.
and, unlike others, I can cut a straight line
WillS
Re: Will's Thread
Reply #97 on:
December 12, 2009, 10:23:54 PM »
it will sound louder,
if you remove the cats then that would lower the temp.
but as far as performance increase on a lambda system(closed loop) i doubt any better, probably worse.
the dp kit is all about the ecu, the pipes alone are only a small part on these new E3 bikes.
MadDuck
The anti-
Re: Will's Thread
Reply #98 on:
December 12, 2009, 11:29:42 PM »
+1 on what Will said. You are better off just getting a slip on kit with the ECU. Termis are great. You could also run Arrows, Yoshimuras or Akros, all without the ECU and see how that goes. Won't be as good as with the DP ECU but would still improve things a small bit. No matter what, stock or not, the 848 has nothing on the 999 in terms of heat on your butt and right thigh.
teddy037.2
Re: Will's Thread
Reply #99 on:
December 13, 2009, 12:17:45 AM »
yosh makes duc exhausts?
MadDuck
The anti-
Re: Will's Thread
Reply #100 on:
December 13, 2009, 06:29:16 AM »
Quote from: teddy037.2 on December 13, 2009, 12:17:45 AM
They did last year when I got the full system for the 750.
Re: Will's Thread
Reply #101 on:
December 13, 2009, 06:58:27 AM »
Quote from: teddy037.2 on December 12, 2009, 10:16:52 PM
That was the hacksaw damnit!!
Quote from: mac900 on December 12, 2009, 11:29:42 PM
Or the Daytona. That thing would roast your ass!!
But like Mac and Will stated, you will only get the noise if you only core the pipes. It will sound better, but the ecu will still try to lean everything out, especially at lower rpms. If I were you, I would go rob a bank (you look local enough, you will get away with it in this state) and buy a set of Zard slip ons and tune it up with Nemesis system.
Brutale
Have you seen my Titianium member?
Re: Will's Thread
Reply #102 on:
December 13, 2009, 07:17:23 AM »
Quote from: DRKWNG on December 13, 2009, 06:58:27 AM
Cmon now, I'd hate to send a fellow board member to the Federal slammer!!!
'07 Sport 1000, Black, slightly modded
Re: Will's Thread
Reply #103 on:
December 13, 2009, 07:20:52 AM »
Quote from: Brutale on December 13, 2009, 07:17:23 AM
LOL Whatever! You know the state of Hawaii would NEVER allow someone to actually go to jail.
Brutale
Re: Will's Thread
Reply #104 on:
December 13, 2009, 07:26:41 AM »
Quote from: DRKWNG on December 13, 2009, 07:20:52 AM
You're right, the state wouldnt...
6
7
8
9
29
