Source for factory wiring/crimps?
Started by TAftonomos, August 23, 2009, 06:45:11 AM
angler
#15
Quote from: RB on September 02, 2009, 06:06:36 AM
http://www.onlinecomponents.com/
Part numbers for the nice AMP connectors on the S2R:
part number # of pins
SuperSeal 1.5 Series AMP 282079-2 1 Plug
SuperSeal 1.5 Series AMP 282080-1 2 Plug
SuperSeal 1.5 Series AMP 282087-1 3 Plug
SuperSeal 1.5 Series AMP 282088-1 4 Plug
SuperSeal 1.5 Series AMP 282089-1 5 Plug
SuperSeal 1.5 Series AMP 282090-1 6 Plug
SuperSeal 1.5 Series AMP 183025-1 female Receptacle Contact for Plug (Loose)
SuperSeal 1.5 Series AMP 282110-1 female Receptacle Contact for Plug (Strip)
SuperSeal 1.5 Series AMP 281934-3 universal for 16 awg Wire Seal Red
SuperSeal 1.5 Series AMP 880810-1 2 Boot
SuperSeal 1.5 Series AMP 880811-2 3 Boot
SuperSeal 1.5 Series AMP 493581-1 4 boot
SuperSeal 1.5 Series AMP 880814-1 5 Boot
SuperSeal 1.5 Series AMP 282103-1 1 Cap (socket)
SuperSeal 1.5 Series AMP 282104-1 2 Cap (socket)
SuperSeal 1.5 Series AMP 282105-1 3 Cap (socket)
SuperSeal 1.5 Series AMP 282106-1 4 Cap (socket)
SuperSeal 1.5 Series AMP 282107-1 5 Cap (socket)
SuperSeal 1.5 Series AMP 282108-1 6 Cap (socket)
SuperSeal 1.5 Series AMP 183024-1 male Tab Contact for Cap (Loose)
SuperSeal 1.5 Series AMP 282109-1 male Tab Contact for Cap (Strip)
I just added the part number for the 4 position boot. I'm placing an order for a couple of 4 position assemblies for the headlight.  Word of warning - TYCO has made this line obsolete and Online Components has LONG backorders for some pieces like the male posts.  Luckily I don't need any of those.
<Edit>
CRAP!  I just went to check out and Online Components requires a $35 minimum order.  Currently, for 2 4 plugs and all the components (in case I screw up the first time) my total is $11.  Anybody need some connectors?  I'll take a tour of the bike later and see if I could use those connectors anywhere else.
I checked first with the board member and he has them, but won't have access to them until middle of December because of a move......
RB
thanks angler, i just updated my post to include the number for the 4 position boot.
I wish i could help you with your order but i ordered all my stuff last year......and i might get to building the harness this year....ha!
I could use a few bits and bobs. Being just down the street would make for any easy group buy. Let me know or maybe start a group buy thread?
angler
Quote from: yuu on November 10, 2009, 08:10:50 AM
I'd be happy to order whatever you need or start a group buy thread.  When I went to check out, I noticed that they were out of the 4 position boot and it will take like 8 weeks to backorder.
Where would one start a group buy thread?
DucHead
More and more I want to re-route some wiring.
How many different gauges of wire are there?  I have a wire cutting tool that appears to have gauge measuring holes.  But I'm not sure that's what they are...   ???
12+5+3=20 years of education and I'm dumb.   :-\
Most of the wiring on a Duc is 16 ga. The stuff for the ecu is lighter, but I'm not sure by how much.
DucHead
Quote from: ducpainter on November 10, 2009, 04:06:45 PM
Thanks DP.
Does anyone know what wire type/amp rating?
Quote from: angler on November 10, 2009, 09:31:10 AM
Herm... of course the 4 is out.  I was thinking of that for headlight work... But there's some other stuff.
A thread might be over kill - since it seems any of the interested players have already piped up in here.  Maybe we just trade some email/pms?
TAftonomos
When you say male posts do you mean the actual crimps of the male end of the plug?  The male crimps/internals are kind of important if you are redoing your harness.
Then again, if you've come up with a better solution, please let me know.  Since I've got to shorten both ends, I don't mind going to a entirely different connector, as long as it's as good as the oem stuff (NOT weatherpack crap, etc).
angler
Quote from: TAftonomos on November 11, 2009, 11:43:52 AM
These things are ala carte; each component part is sold separately.  The male posts are the actual male crimps that then get assembled into the plastic body with various other seals.
I'm not redoing my harness - yet.  After pulling the headlight and dropping the gauges I would sure love to get rid of some of that mess.  I'm just looking for the female side of the headlight plug.  If I could find a junked headlight or pigtail, I would be just as happy as I could just graft that into the headlight I have.
I was planning to got through RB's entire list and post prices and availability, but it has been a busy day.
TAftonomos
I may have a pigtail for you, I've got a few harnesses laying around that I've pulled connectors from.   [thumbsup]
angler
Quote from: TAftonomos on November 11, 2009, 11:59:43 AM
Awesome!  Let me know.....
angler
Here are prices and availability:
in stock  $1.51 282079-2 1 Plug
in stock  $1.13 282080-1 2 Plug
in stock  $1.42 282087-1 3 Plug
in stock  $1.45 282088-1 4 Plug
in stock  $2.41 282089-1 5 Plug
backorder $2.12 282090-1 6 Plug
in stock  $0.19 183025-1 female Receptacle Contact for Plug (Loose)
in stock  $0.14 282110-1 female Receptacle Contact for Plug (Strip)
in stock  $0.11 281934-3 universal for 16 awg Wire Seal Red
in stock  $2.48 880810-1 2 Boot
in stock  $2.74 880811-2 3 Boot
backorder $1.94 493581-1 4 boot
Dont' Stock    880814-1 5 Boot
in stock  $0.95 282103-1 1 Cap (socket)
in stock  $0.97 282104-1 2 Cap (socket)
in stock  $1.14 282105-1 3 Cap (socket)
in stock  $1.27 282106-1 4 Cap (socket)
in stock  $2.41 282107-1 5 Cap (socket)
in stock  $2.53 282108-1 6 Cap (socket)
backorder $0.15 183024-1 male Tab Contact for Cap (Loose)
in stock  $0.12 282109-1 male Tab Contact for Cap (Strip)
Formatting is kinda effed - sorry.  Turns out they do have the male contacts in "strip" format.  From TYCO that means "Strip mounted on a metal carrier and shipped on a reel for use with semi-automatic application tooling." I added it to my cart and it allowed me to add just one, not a whole roll, but who knows.
If TAftonomos can provide a pigtail, I don't need to order anything.  Otherwise, I'm in.....
RB
When i ordered my plug contacts, i ordered the strip. They will work in regular crimps once you remove them from the strip. I actually like ordering the strip, because they aren't loose and less prone to get lost.
angler
Quote from: RB on November 12, 2009, 02:18:33 AM
How many pieces are on each strip?
