Hey guys, I have been working on this project since May, it is really coming together and my "parts needed" list is coming down to single digits! There is still a lot of welding/fab work to do but I will post a full build thread when it gets done. Don't mind the ratchet straps/duct tape/wood blocks they are for mock up only so no jokes! I will be happy to answer any questions until then. I apoligize for no good side shots, my shop is pretty narrow, bikes only!
BTW, this is a 2000 M900 S.i.e. that I picked up off of here after it was wrecked. I wanted 10 spoke Marchesini wheels, which led to the spiral of mods seen here:
10 Spoke cast Marchesinis with Pilot Powers (thanks TAftonomos
999 Forks, radial masters, clip ons, and rotors (not here yet)
996 Steering damper under the bottom triple tree
S4 triple trees (upper still needs to be machined for 999 forks)
Frame sleeved internally and braced to strengthen it
Pod filters (should be here tomorrow)
Sargeant seat
Custom rearsets
996 Single sided swingarm
748 Showa shock and linkage
Arrow carbon exhaust cans from an S4RS
It will be painted Gunmetal/Red frame like the S4Rt's
I still need to figure out what headlight I am going to run, feel free to offer any opinions. The options so far are: Stock, 696, dual round, ?
Next is finishing up the rear of the frame and exhaust hangers, then to build some headers.
If you read my thread about fitting an S2R dash to it, for the time being I will just be replacing my gauge faces with custom white ones. I have a speedo sensor and can get it to mount, and I am fairly sure I can get the S2R dash to work but the problem is with the wiring. The S2R dash has no wires between the actual gauges and the plugs, only pins coming out of the circuit board. What this means is I cannot splice it in without having one of those plugs, and I am not willing to buy a whole wiring harness just to chop the plug off. If you happen to have a damaged harness with the right dash plug, send me a PM. Thanks.
