April 29, 2024, 07:00:08 AM
HELP chain is slipping out!!! eeeek
Topic: HELP chain is slipping out!!! eeeek (Read 6478 times)
Re: HELP chain is slipping out!!! eeeek
Reply #15 on:
May 23, 2008, 04:35:48 PM »
Here's how it should look when assembled:
onaboat
Reply #16 on:
May 23, 2008, 04:47:17 PM »
ohhh DUHH
heres how mine looks like, i guess i messed up pretty bad!!!
did i install it inside out too?
and here i had to take the plastic piece off because it was rubbing against it
Last Edit: May 23, 2008, 04:49:26 PM by onaboat
printman
Check out my a.....
Reply #17 on:
May 23, 2008, 04:59:35 PM »
turn the sprocket over so the teeth side is on the outside. It should line up then.
nice rivet job on the link
I'll update this later at a convenient time Thank you for tuning in.....
onaboat
Reply #18 on:
May 23, 2008, 05:14:18 PM »
actually i just checked my stock sprocket and it looks like the sprocket is suppose to be on with the teeth in, or maybe not i dunno but the stock sprocket has the sprocket retainer in-print on the side i installed it on. sorry i don't know if that even makes sense
Reply #19 on:
May 23, 2008, 05:16:41 PM »
Quote from: onaboat on May 23, 2008, 05:14:18 PM
You're correct, teeth toward the inside for a 695.
The pic I posted is of a 900 motor, sprocket is teeth out on those because of the wider rear rim on 900s.
onaboat
Reply #20 on:
May 23, 2008, 05:20:44 PM »
ok kool, thanks a lot guys, yall may have saved me a lot of headache and my bike
onaboat
Reply #21 on:
May 23, 2008, 05:24:17 PM »
maybe the mods can sticky this as how NOT to install a new sprocket.... i feel like such a dork
Reply #22 on:
May 23, 2008, 06:44:19 PM »
Don't worry, everybody makes errors.
Best part is, you'll always get it right from here on.
printman
Check out my a.....
Reply #23 on:
May 24, 2008, 04:37:49 AM »
Quote from: Speeddog on May 23, 2008, 05:16:41 PM
Really, I haven't been on the 695. I was thinking like my 900.
Learned something new today
BastrdHK
Quit complaining, and ride the damn thing!
Reply #24 on:
May 24, 2008, 09:51:30 AM »
Quote from: onaboat on May 23, 2008, 04:47:17 PM
ohhh DUHH
Put your chain guides/guards back on....it is supposed to rub against them. Unless you prefer your chain taking bites out of your nice new swing arm. Since the chain is made out of very strong, dense steel it will eat everything else in its way. Unfortunately, my swing arm has the scars to prove it.
M-ROCin' it!!!
DuciD03
.... when did that happen...?
BTW: thats a bad pic of Bono, not me .... ;)
Reply #25 on:
May 24, 2008, 10:14:08 AM »
.... and heres an example of when you need to clean and lube your chain ...
(sorry i couldn't resist) Cheers D
Quote from: Speeddog on May 23, 2008, 04:35:48 PM
.... all the world is yours.
DarkStaR
Reply #26 on:
May 24, 2008, 04:38:30 PM »
Quote from: DuciD03 on May 24, 2008, 10:14:08 AM
What chain?
That looks like a sprocket to me.
For $50 you can touch my
Reply #27 on:
May 24, 2008, 04:50:51 PM »
Quote from: onaboat on May 23, 2008, 12:28:48 AM
i think it might be slipping out because i didn't tension it evenly? i re-tensioned the change again and took it for a ride its still slipping but not nearly as far. i'll try to take a pic of it after i ride tomorrow, i tapped it even already.
thanks
Btw, if you have problem....riding it further in a case like this particular one to try and find said problem is not advised.
DuciD03
Reply #28 on:
May 24, 2008, 06:48:45 PM »
exactally; note the buildup of dirt incased in oil and the sprocket that hasn't seen a chain in a while because ...?
Quote from: DarkStaR on May 24, 2008, 04:38:30 PM
What chain?
DarkStaR
Reply #29 on:
May 25, 2008, 07:13:34 AM »
Quote from: DuciD03 on May 24, 2008, 06:48:45 PM
That's not dirt incased in oil. That's black gold!
That's what holds some peoples bikes together and keeps them running.
