For the brake experts: '05 620 Dark rotors...
Started by Teutonics, August 30, 2009, 07:24:35 PM
Teutonics
Looking for rotors for my bike, but saw on Ca Cycleworks that '05 620 Dark rotors use a different part number.  What was different, and will non-dark rotors fit my 900ie?  Was it single disc with a different offset?  Are 2005 620 non-dark rotors the same as most other models?
Atlanta, GA - 2002 M900ie
2005 was a little bit of an odd year.  Early 620s has the possibility of still coming with the 320mm 10mm Offset rotors and the 4 pot calipers.  Though most came with 300mm 0 Offset rotors and the 2 pot calipers.
To fit a 900, you'll want 320mm 10mm Offset rotors.  Basically *every* monster made until the introduction of those 300mm rotors used those rotors
