S4 Swingarm removal
Started by imbroglio, August 31, 2009, 04:19:21 PM
imbroglio
I cant get the swingarm pivot out!
Circlips are removed, pinch bolts removed.
Still solid as a rock.
What am I missing?
Do one thing every day that scares you. (Eleanor Roosevelt)
AlbieS4
When you took pinch bolts out did you remove the collet nuts as well .
Proud owner of M1100S
gage
I had the same issue.
Take a look at this thread. I found that I needed to take out the clamp bolt and the clamp pieces all the way out. Once those were out it came out no problem
http://ducatimonsterforum.org/index.php?topic=15487.0
Good Luck
