July 27, 2024, 07:25:44 PM
DIY Painting Tips
11
12
13
14
67
Topic: DIY Painting Tips (Read 395238 times)
Zaster
Only Pam can touch my
2007 S4RS (sold) , 2008 1098S (sold), 2013 1199R,
Re: DIY Painting Tips
Reply #165 on:
January 09, 2009, 06:10:11 PM »
Quote from: just another painter on January 09, 2009, 06:03:59 PM
I used to use S-W primer and clear and I used a little bit of the Dimension color.
I don't use them any longer for a reason. The clear stayed soft too long for moto tanks and the primer shrunk.
I can make specific product recommendations for PPG and HOK.
Cool,
Let me have it
Reply #166 on:
January 09, 2009, 07:17:36 PM »
Quote from: Zaster on January 09, 2009, 06:10:11 PM
Cool,
Let me have it
I would use HOK KS 10 for a sealer and PPG DCU 2060 flat clear. The only downside of using different brands is you need to buy two different activators. PPG does have a urethane sealer, but I don't use it. If you want I can get the product # for the ppg sealer. HOK doesn't sell a flat clear per se. They offer a flattening agent for their clear. If you use one manufacturer you would save some money as activators are expensive. I use HOK reducers.
You can use any dark black metallic or straight black for color...the metallic kind of disappears under the flat clear.
Zaster
Reply #167 on:
January 11, 2009, 05:15:09 PM »
Hopefully this will be the last time I'll bug you...
How much shoud I expect to pay for a professional to paint my tank.
Thanks again
Reply #168 on:
January 11, 2009, 05:24:08 PM »
Quote from: Zaster on January 11, 2009, 05:15:09 PM
Thanks again
11ty billion dollars.
Zaster
Reply #169 on:
January 11, 2009, 06:05:32 PM »
Quote from: just another painter on January 11, 2009, 05:24:08 PM
Very funny
I can get everything from work except the color sealer, paint (well reducer and accelerator) and clear
for $80. Just wanted to see what I would be saving by doing it by myself.
Reply #170 on:
January 11, 2009, 06:11:03 PM »
Quote from: Zaster on January 11, 2009, 06:05:32 PM
Very funny
It's really hard to say.
If he has materials in house it might be reasonable...
you'd have to ask around in your area.
Keep in mind that you get what you pay for if you're lucky.
The advantage the pro would have is a dust controlled environment, which is essential on a matte finish.
Reply #171 on:
January 19, 2009, 09:23:46 PM »
Quote from: ducpainter on January 09, 2009, 07:17:36 PM
I use HOK reducers.
RU300?
Ever thought about leaving the KS?
SaltLick
Reply #172 on:
February 01, 2009, 07:06:07 AM »
ducpainter im having my tank painted but i have to do the prep work. Aftermarket paint job on there still and one place where they pulled a dent out and its bondoed there. Is there a thread out here, or can you give me basic instructions on how to prep the tank for this? Tools i have are an electric sander. Old bondo has to come off, its thick in some spots. What grit will get bondo off? Do i just sand the hell out of the whole tank till all the bondo is off, then primer it a few times with wetsanding in between primer coats?
Reply #173 on:
February 01, 2009, 03:00:40 PM »
Quote from: SaltLick on February 01, 2009, 07:06:07 AM
What's your plan for replacing the filler?
It's there for a reason....like primer won't fill the damage.
How come your painter isn't doing the whole job?
Zaster
Reply #174 on:
February 01, 2009, 07:41:02 PM »
I found out that one of our stores carries HOK and the salesman knows a painter that specializes in motorcycles.
Any recommendations for what matte blacks/clears to use for a plastic tank/seat cowl?
If I wanted to do a mad max scheme, how would I go about getting brackets, radiator, oil cooler etc. black.
I hear that anodizing things black eventually makes them start turning purple.
Reply #175 on:
February 01, 2009, 08:09:33 PM »
Quote from: Zaster on February 01, 2009, 07:41:02 PM
Sand all the parts you want flat black with 80-120 grit. Apply an epoxy primer, allow it to cure a few days. Sand it with P400 (preferably with water) and apply the HOK KS12 after a few minutes apply a second coat of the KS12. Allow 24 hours to cure and re-install parts you're done.
As for the bodywork use the same process. If it's already painted skip the epoxy primer part.
fulltilt
Reply #176 on:
February 03, 2009, 01:58:27 PM »
Hi, I have a couple of used carbon fiber parts that have yellowed and clouded from UV, or whatever. They have minimal epoxy layup. What is the best technique/process and materials to 1) remove as much of the the degraded material (if its even possible), 2) prep, and 3) paint/clear coat. I have a gun and compressor/dryer big enough to do fenders, etc. Thx
Reply #177 on:
February 03, 2009, 07:18:53 PM »
Quote from: fulltilt on February 03, 2009, 01:58:27 PM
Wash it, sand it with 220, prime the living shit out of it, and sand with 400 after all the holes are filled. Seal and paint.
You can use polyester putty to fill the stubborn pinholes and re-prime.
jimh
Reply #178 on:
February 04, 2009, 11:35:54 AM »
OK, here's a new question: I have a '99 750 Monster in Yellow. I have adapted the small fairing from an S2R to it, the fairing is also yellow, but they aren't the same yellow, by any stretch. the bike is bright, deep yellow, and the fairing is more of a creamy yellow. But color-rite only lists one yellow for all the Monsters and Superports from '99 through '08. Are they wrong? or has the paint color drifted over time that much?
I want to have the bike repainted in a tri-colore scheme, but that is budget-limited, i was thinking a rattle-can of
color-rite yellow would make the fairing less of an eyesore. based on my quick research, i have no idea whether or not that will do what i want.
any suggestions?
jimh (duvall, wa)
1999 yellow M750: DP carbon high pipes, FCR 39's, dyna coils, cut airbox, K&N filter, later-style bikini fairing with
mis-matched yellow.
Reply #179 on:
February 04, 2009, 03:58:33 PM »
Quote from: jimh on February 04, 2009, 11:35:54 AM
any suggestions?
My experience is that there is no one yellow or one red. The darks are all different also.
Ducati does not paint their own stuff. It is painted by whatever company builds the part, or their sub-contractor.
That opens the color to variances due to brand of paint, process (do they paint over white or gray...was it a good mix), and technique...did Guido put all three coats on or was he a little buzzed after lunch.
I don't think the color-rite stuff will necessarily match either part.
Save your money and get the bike painted when you can afford it.
11
12
13
14
67
