July 27, 2024, 09:17:45 PM
DIY Painting Tips
13
14
15
16
67
Topic: DIY Painting Tips (Read 395264 times)
Re: DIY Painting Tips
Reply #195 on:
February 11, 2009, 03:55:56 AM »
Quote from: Zaster on February 10, 2009, 08:18:34 PM
Can you enlighten me about compressor ratings?
The detail HVLP gun I'm looking at requires 8 CFM @ 30 PSI
My compressor is rated at 6.4 CFM @ 90 PSI and I can't find a conversion or
formula that gives me the CFM rating for my cmpressor at 30 PSI.
What say the expert? (20 gal tank and 4.5 hp rating).
It will work. There is no conversion because it is dependent on too many factors
If you are spraying multiple items the pump will run pretty much continuously but it should keep up.
A quick test is to run an open fitting at the pressure required for several minutes. If there is no pressure drop at the regulator you should be good to go.
Don't forget to get a high flow coupler and fitting for the gun.
SaltLick
Reply #196 on:
February 11, 2009, 06:05:58 AM »
how long does it take for you to say put some bondo on a tank, primer it and paint it?
just curious. i have my tank in to be painted and was just wondering how long it takes, i mean how many days does it take.
Reply #197 on:
February 11, 2009, 06:33:32 AM »
Quote from: SaltLick on February 11, 2009, 06:05:58 AM
I really can't say how long it takes someone else.
I tell my customers 3 weeks...that allows for curing time so I can package and ship.
Zaster
Only Pam can touch my
2007 S4RS (sold) , 2008 1098S (sold), 2013 1199R,
Reply #198 on:
February 11, 2009, 06:34:56 PM »
Quote from: ducpainter on February 11, 2009, 03:55:56 AM
Ducpainter,
Thanks for the advice and the heads up, bought the coupler, fitting and gun at work today.
Last Edit: February 11, 2009, 06:36:45 PM by Zaster
Reply #199 on:
February 11, 2009, 06:42:03 PM »
Quote from: Zaster on February 11, 2009, 06:34:56 PM
Ducpainter,
You work at a PBE shop?
Zaster
Reply #200 on:
February 11, 2009, 06:51:56 PM »
Quote from: ducpainter on February 11, 2009, 06:42:03 PM
I work at the local CARQUEST auto parts warehouse and they carry everything I need at employee prices.
They own PBE shops where I can get the paints mixed as well.
Reply #201 on:
February 11, 2009, 06:58:59 PM »
Quote from: Zaster on February 11, 2009, 06:51:56 PM
Sweet.
What did you buy for a gun?
Zaster
Reply #202 on:
February 11, 2009, 07:04:59 PM »
Quote from: ducpainter on February 11, 2009, 06:58:59 PM
Sweet.
$62 plus tax
Reply #203 on:
February 11, 2009, 07:06:33 PM »
Quote from: Zaster on February 11, 2009, 07:04:59 PM
$62 plus tax
Cheap enough...
The high flow fittings help.
Zaster
Reply #204 on:
February 11, 2009, 07:12:43 PM »
Quote from: ducpainter on February 11, 2009, 07:06:33 PM
Cheap enough...
Let me know if you have a store close to where you live and I get in contact with the owner/manager to
make sure they give you a good price. We have 3,400 stores nationwide.
Last Edit: February 11, 2009, 08:13:17 PM by Zaster
Reply #205 on:
February 11, 2009, 07:16:58 PM »
Quote from: Zaster on February 11, 2009, 07:12:43 PM
Thanks.
Zaster
Reply #206 on:
February 16, 2009, 05:25:34 PM »
I"m fixing to remove the radiator from my S4RS to adjust the mounting taps
I bent during a mishap a while back. Since I want to paint the bike matte black
I thought that the radiator should be the same color. Do you think that the SEM
Solve Cleaner (38373) and the Black Metal Edging Primer (39673) would do the job.
Reply #207 on:
February 16, 2009, 05:35:36 PM »
Quote from: Zaster on February 16, 2009, 05:25:34 PM
I don't really use a lot of SEM stuff.
I prefer epoxy primers on anodized metal.
Zaster
Reply #208 on:
February 16, 2009, 06:16:13 PM »
Excuse my ignorance..is an aluminum looking radiator anodized?
Reply #209 on:
February 16, 2009, 06:32:26 PM »
Quote from: Zaster on February 16, 2009, 06:16:13 PM
I'm betting it is.
If it isn't it should be etched with an aluminum prep.
Either way I like epoxy on aluminum.
13
14
15
16
67
