October 06, 2024, 10:04:17 AM
Please Help
DIY Painting Tips
25
26
27
28
67
Topic: DIY Painting Tips (Read 402491 times)
Enjoying the ride
Re: DIY Painting Tips
Reply #375 on:
December 08, 2009, 02:50:39 PM »
Quote from: ducpainter on December 08, 2009, 12:33:19 PM
Fiberglass is not the best choice for bonding to plastic. It doesn't really stick.
JB weld would be better, but the regular kind takes forever to set up. If you had the quick set JB weld it should work. Just scuff up the bonding area with coarse (36) grit paper.
DP,
any other name for JBweld?
Reply #376 on:
December 08, 2009, 02:59:46 PM »
Quote from: Darkmonster620 formerly M620D on December 08, 2009, 02:50:39 PM
DP,
It may be easier for you to tell me what you can get.
JB weld is an epoxy type material. Epoxies, in general, stick to most anything if the surface is prepped correctly.
You kind of need a quick set product so you can hold it in place. It would be tough to clamp without marring paint.
Enjoying the ride
Reply #377 on:
December 08, 2009, 03:21:44 PM »
Quote from: ducpainter on December 08, 2009, 02:59:46 PM
>>> I'll do my homework
Quote
Like two component epoxy?
Quote
Fender all scratched from fall, will have to redo grills, fell on floor on shop and stepped on them...No worries, lots of used air filters to get mesh from at the shop...
Reply #378 on:
December 08, 2009, 03:23:13 PM »
Quote from: Darkmonster620 formerly M620D on December 08, 2009, 03:21:44 PM
>>> I'll do my homework
All epoxies are 2K
Enjoying the ride
Reply #379 on:
December 08, 2009, 03:32:46 PM »
Quote from: ducpainter on December 08, 2009, 03:23:13 PM
All epoxies are 2K
Basically any of those that says that bonds metall to plastic will do?
Reply #380 on:
December 08, 2009, 03:34:20 PM »
Quote from: Darkmonster620 formerly M620D on December 08, 2009, 03:32:46 PM
Yup...
but look for a quick set product if you can.
Enjoying the ride
Reply #381 on:
December 08, 2009, 03:39:49 PM »
Quote from: ducpainter on December 08, 2009, 03:34:20 PM
Yup...
I'll do...But, back to cutting and painting the grills. I sanded the fender with 340 grit to smooth it out, with what can I fill the scratches[the larger ones]?
Reply #382 on:
December 08, 2009, 03:50:52 PM »
Quote from: Darkmonster620 formerly M620D on December 08, 2009, 03:39:49 PM
There's a few ways...depends on how deep the scratches are.
I usually prep/smooth with 180 grit and prime.
You can try a primer surfacer, and then sand and paint. It depends also of the makeup of the product. Some fill better than others.
If you can feel the scratches with a fingernail use a polyester putty and then prime and sand. Try not to apply the putty over bare plastic.
Remember the fender is plastic and you should use an adhesion promoter intended for plastics before priming over bare plastic.
Enjoying the ride
Reply #383 on:
December 08, 2009, 03:54:36 PM »
Quote from: ducpainter on December 08, 2009, 03:50:52 PM
OK, thanks, the "largest" scratch is about 1mm deep...
Reply #384 on:
December 08, 2009, 03:57:55 PM »
Quote from: Darkmonster620 formerly M620D on December 08, 2009, 03:54:36 PM
That will need filling with putty.
Enjoying the ride
Reply #385 on:
December 16, 2009, 03:28:21 AM »
adhesion promoter
dp,
from these brands, basf, akzo nobel,dupont, lanco, from which one can i get the adhesion promoter?
Clearcoat wise, I'll be using a BASF made brand, it'll be flat cleared.
What about this,
I tried to fix it the best I could before the polyester putty, did I actually messed up or
Last Edit: December 16, 2009, 11:59:09 AM by Darkmonster620 formerly M620D
Reply #386 on:
December 16, 2009, 01:22:50 PM »
Quote from: Darkmonster620 formerly M620D on December 16, 2009, 03:28:21 AM
dp,
What about this,
They probably all have one
bdfinally
Reply #387 on:
January 01, 2010, 08:34:38 AM »
Happy New Year, Nate
I've got a carbon fiber SBK front fender that I want to do something with. The thing has fogged up in parts of it and I'd like to see what you think, is it the clear coat and can be fixed or do I just need to paint the whole thing. here are some pics to help give you an idea of what I'm dealing with.
Thanks for your effort in this DIY project, it's much appreciated
Reply #388 on:
January 01, 2010, 08:57:53 AM »
It probably has not been cleared.
Try washing with denatured alcohol. If the fogginess goes away clear it with an automotive urethane.
Otherwise you'll need to paint it.
Enjoying the ride
Reply #389 on:
January 01, 2010, 09:35:14 AM »
Hey Nate,
Happy New Year...
Been doing a lot of sanding, how far I need to go on the headlight bezel?
25
26
27
28
67
