December 22, 2024, 06:38:18 AM *
Pages: 1 ... 28 29 [30] 31 32 ... 67   Go Down
Author Topic: DIY Painting Tips  (Read 412781 times)
« Reply #435 on: April 21, 2010, 02:10:47 AM »
I dug this up because there have been a bunch of threads around the board about using epoxy paint on various items.
Epoxy is great stuff, and I use it on all bare metal and often as a base for surfacers.
It sprays well, sticks to the surface like crazy,and also 'most' anything you put over it sticks to it.
Epoxy is not the best choice as a topcoat that is exposed to the elements however.
It is the reason carbon fiber looks like junk after a year or so if not cleared with a UV protective clear...
so if you want your hard work to hold up in the elements...
pick a different product as a topcoat.
« Last Edit: April 21, 2010, 02:19:23 AM by ducpainter » Logged
djrashonal
« Reply #436 on: April 21, 2010, 04:53:16 AM »
Speaking of carbon fiber, what do you think the best way to paint my carbon fiber belt covers is? what should I use? I'd like to paint it flat black, or as flat as it can be with a clear coat.
01 SSSSSSS4 - Sold
'09 Triumph Bonneville
S2R800 dark - searching for
« Reply #437 on: April 22, 2010, 02:40:59 AM »
Do you have access to professional spray equipment?
djrashonal
« Reply #438 on: April 22, 2010, 07:01:23 AM »
Yea but it would cost me. I'll arrange it if needed though
01 SSSSSSS4 - Sold
mojo
'99 M900S
« Reply #439 on: April 22, 2010, 03:19:33 PM »
Quote
Also, it provides some of the best corrosion protection you can buy.
Some people are like slinky's.  They serve absolutely no purpose, but they always bring a smile to your face when you push them down the stairs.
« Reply #440 on: April 22, 2010, 05:15:58 PM »
You betcha. waytogo Grin
If you want what I would consider a 'good' job...
Sand with 400...
prime with an epoxy and then wet on wet spray with a urethane topcoat.
You can modify the gloss as necessary with whatever manufacturers product you're using
silversled
« Reply #441 on: April 23, 2010, 07:15:26 AM »
Ducpainter,
First of all, thanks for allowing us to peek into your well of experience and expertise.
Based on 30 pages of Q&A, I think I've formulated how to address my issue but I thought I'd ask since I don't think my situation has been directly represented.
I'm giving a 2007 Silver S2R1000 a second lease on life after falling victim of being parted out by the previous owner.  The previous owner peeled off all the fuel tank stripes leaving sharp clear coat edges and exposing "virgin" basecoat paint where the stripes used to be.  Otherwise the tank is in great condition with only superficial storage scuffs in the clear coat.
What is the best way to bring the tank back to stock finish?  I'm assuming these steps:
- Degrease/clean
- Fair clearcoat edges and sand clearcoat
- Clean and Tack
- Apply Factory black strip
- Clear entire tank
Can you provide any advice if this is the proper steps and what paper grit and clearcoat type to use (catalyzed urethane?)?
Thanks.
« Reply #442 on: April 23, 2010, 01:35:48 PM »
Ducpainter,
- Degrease/clean
- Clean and Tack
- Clear entire tank
Thanks.
You're close...
Unfortunately I've never had any luck feathering back the clear without damaging the base coat...particularly a metallic.
The fastest and easiest way is to bite the bullet and plan on spot priming and painting the area.
ducrider45
Just Ride!
« Reply #443 on: April 27, 2010, 08:13:51 AM »
DP, I plan on Powder coating several parts on my bike. Many of them are anodized aluminium. What do I need to do to the parts for prep? Is it as simple as washing the parts? Do I have to chemicly remove the anodizing first? I will strip all of the painted parts.  I have never used powder before. Is it similar to spraying paint? Thank you.
 Thomas Jefferson
« Reply #444 on: April 27, 2010, 01:19:21 PM »
I have to be honest. I'm not a powder coater.
If I was painting an anodized part I would sand/scotchbrite, epoxy prime, and urethane topcoat. That is an accepted process for Mil/Aerospace. Those processes address the issue of corrosion. Powder processes don't as there is no primer or coating other than the topcoat.
If powder will stick to anodizing I'd do the same thing, but I don't know if it will.
ducrider45
Just Ride!
« Reply #445 on: April 27, 2010, 02:43:23 PM »
Thank you.
 Thomas Jefferson
Enjoying the ride
« Reply #446 on: April 27, 2010, 03:55:57 PM »
hey DP,
got my bike finished, sorry no pics yet, heavens have opened the rainy season big time here; so, in accordance to riding in the rain, I washed my bike with Coral Blue or something like that motorcycle washing liquid[bottle cracked so I refilled another] and suddenly all flat black parts[front fender, side covers, rear fender and beer tray] are glossy...Cleaned the tank with a 100% towel of mine, no water no soap, still flat black...
what happened?
« Reply #447 on: April 28, 2010, 01:09:02 AM »
hey DP,
what happened?
The blue coral had wax in it. Most commercial wash products do.
Get some wax and grease remover from the shop and wipe the parts down. If they're fresh wait a while.
Enjoying the ride
« Reply #448 on: April 28, 2010, 02:09:40 PM »
Like Formula 89? Or less strong?
« Reply #449 on: April 28, 2010, 02:19:31 PM »
Don't know that product.
I'm thinking like PPG DX330 or DuPont 3939 or DuPont Prep-Sol.
Your parts have been painted for a while. None of those products should hurt it if used according to instructions.
If the parts are less than 30 days old wait.
Pages: 1 ... 28 29 [30] 31 32 ... 67   Go Up
