September 01, 2024, 07:24:45 AM
DIY Painting Tips
31
32
33
34
67
Topic: DIY Painting Tips (Read 398915 times)
Re: DIY Painting Tips
Reply #465 on:
May 07, 2010, 02:06:22 AM »
Quote from: TAftonomos on May 06, 2010, 04:59:40 PM
I'd assume I want a 2 part paint at a min on something like this.
Think a preval can will work to spray epoxy?
I wouldn't use epoxy for the masters, unless that was your primer and you used a 2 part urethane over it.
I don't use epoxy for parts exposed to the sun.
If you reduced sufficiently I believe you could use a Pre-Val and spray multiple thin coats.
Enjoying the ride
Reply #466 on:
May 16, 2010, 05:03:20 PM »
dp,
I'm between purchasing a used, CF fairing for my Monster, it's missing the clips that hold the windscreen; can these be manufactured at home? How can I manufacture them? I'll paint the fairing in flat black as the rest of the bike, so...
scott_araujo
Reply #467 on:
May 16, 2010, 08:11:15 PM »
DP, many older British bikes have a tank that's part chrome and part painted. How do they do this? I would think the paint would flake off if there's chrome underneath.
Thanks,
Scott
Reply #468 on:
May 17, 2010, 01:02:51 AM »
Quote from: scott_araujo on May 16, 2010, 08:11:15 PM
Thanks,
Scott
If the chrome is left smooth it does just that. I've seen lots that have lost their paint. I often wonder what was done to the Monster tanks that were chrome and paint combos
Sometimes the painted area will be lightly sandblasted to achieve enough roughness for paint adhesion. That's what I would do.
ducrider45
Just Ride!
Reply #469 on:
June 02, 2010, 06:39:32 PM »
I plan on painting a alum. bicycle frame. Im looking for a "bassboat" type finish. I have been to the local auto paint store and have not found a paint that meets the "bassboat" spec. Im thinking that this will have to be custom. Im now thinking that it may be a multi stage job. Please tell me if I have got this correct.
1st: epoxy primer
2nd: Heavy metalic flake silver dust coat
3rd: Heavy metalic flake silver color coat
4th: candy orange (# of coats to get desired color/shade)
5th: color sand
6th: clear coat and Decals
7th: final clear coat
Will this work ? thanks.
Last Edit: June 02, 2010, 06:55:27 PM by ducrider45
Thomas Jefferson
Reply #470 on:
June 03, 2010, 12:55:08 AM »
Quote from: ducrider45 on June 02, 2010, 06:39:32 PM
1st: epoxy primer
5th: color sand
Look at House of Kolor for your system. It's available online.
It won't work exactly as you have it, but close.
After the primer you need to decide what color you want to lay your flake over. I've done silver flake over black and over silver. The flake will cover better over a lighter color.
The bassboat flake should be put on in full wet coats so it lays down as flat as possible. You'll need a fairly large fluid tip depending on flake size. You want to limit the number of coats to achieve that flatness. The flake will give you a very rough surface. It will need to be cleared and sanded before the candy orange is applied or you'll sand through the candy showing raw flake.
Depending on whose products you're using you may have to clear the candy before decals and then clear again.
When I do a flake job there is always a minimum of 9 coats of clear.
HTH
Bones
In spanish she calls it
'02 M620 - '00 996
Reply #471 on:
June 28, 2010, 07:24:18 AM »
Hi DP,
so I tried to shoot hot rod black on some test pieces with a gun I got to play around with. didn't work out so hot, so plan b is now to shoot my pieces with rattle can duplicolor paint and follow up with a special lacquer flat clearcoat that is supposedly gas-proof (It's made for model airplanes).
I'm shooting tank, cowl, and fender to emulate the dark color scheme (not color match, just the sheen).
so here are my 2 questions:
I know rattle cans spray much thinner coats than a gun, so I am expecting to end up with 5-6 coats of base and probably 3-4 coats of clear.
started shooting the tank, but so muggy this weekend, I got some light orange peel and some scratches from primer coat also showed up.
can I wet color-sand the base to smoothen it out and if so, 1000, 1600, 2000 grit? or will the clearcoat hide this?
Can a flat clear coat be wet-sanded?
TIA.
I'm a loner, Dottie...a rebel...
Reply #472 on:
June 28, 2010, 12:58:39 PM »
Quote from: Bones on June 28, 2010, 07:24:18 AM
Hi DP,
TIA.
sand the color all you want with 600...but you'll have to apply more. Clear doesn't hide much.
A flat clear can't be touched unless you plan on re-applying.
Bones
'02 M620 - '00 996
Reply #473 on:
June 29, 2010, 09:34:06 AM »
thanks, DP.
I'm hoping by this weekend she will be all back together.
Blue
Oh no, not another
2000 M900ie Dark
Reply #474 on:
July 13, 2010, 06:42:57 AM »
Quote from: ducpainter on June 28, 2010, 12:58:39 PM
So, I just painted my metal monster tank in an attempt to replicate the "dark" paint scheme (tank I was painting came with the stock dark paint with a metallic ghost flame over spray).
Everything was working out really well until the end. The flat clear coat that I was applying started to "fog" out of the nozzle while I was finishing up. The result is a light dusting effect on the tank in a couple of places. Is there no hope? I had thought about sanding or using a rubbing compound, but I thought I would check here first. Using a finger I can wipe some of it off; ideas?
Thanks.
Bones
'02 M620 - '00 996
Reply #475 on:
July 13, 2010, 10:38:17 AM »
is this from a rattlecan?
If so, I had the same problem in some spots and I was able to just use my hand to rub off the textured spots where the clear dried before making contact. just make sure its well dried before you do it.
Blue
Oh no, not another
2000 M900ie Dark
Reply #476 on:
July 13, 2010, 11:16:40 AM »
Quote from: Bones on July 13, 2010, 10:38:17 AM
Cool, thanks for the information and yes, this is from a rattle can. I bought the bike with a "custom" paint job on the tank (see flames in my previous post). It may be cool to some, but it isn't for me. I wanted to see what the bike looked like matte black as it was originally. If I like the color, I am planning on having it professionally done this winter.
I really like gloss black, though...
<looks in the garage at the gloss black truck and other the gloss black motorcycle>
Oh and how long should I wait after painting before I give the bike a bath?
scott_araujo
Reply #477 on:
July 13, 2010, 11:31:22 AM »
You can sand the flat clear lightly once it's dry and then recoat with the same. If you just sand or use rubbign compound it probably won't match the final finish on the rest of the tank.
Scott
dbran1949
2007 S4RS Black Termis
Reply #478 on:
July 13, 2010, 11:37:47 AM »
Quote from: Blue on July 13, 2010, 11:16:40 AM
Also a fan of the gloss black
Blue
Oh no, not another
2000 M900ie Dark
Reply #479 on:
July 19, 2010, 09:08:15 AM »
Here are a few photos of the new paint job.
DupliColor T090
Krylon Matte Clear
I waited a week after painting to handle the tank, put it back on the bike and to wash the whole bike.
It is not a perfect match; a bit lighter than the stock dark matte on the bike (front fender).
I did this to see if I like the dark or if I want to go with gloss black (professional, two-stage). I am out about $25 for two cans of paint, one can of clear and a quart of acetone to remove the custom flame job. It took no more that 3 hours total; 2 hours preparing the tank and an hour painting. Of course, there was the week that I could not ride (this bike).
Last Edit: July 19, 2010, 09:16:06 AM by Blue
31
32
33
34
67
