September 01, 2024, 07:25:08 AM
DIY Painting Tips
32
33
34
35
67
Topic: DIY Painting Tips (Read 398916 times)
scott_araujo
Re: DIY Painting Tips
Reply #480 on:
July 19, 2010, 12:27:05 PM »
Looks good and just like mine with the same paints, just a little more sheen and shine in the sunlight than the stock Dark color. Careful filling up, I don't think these paints are very resistant to gasoline.
Scott
Meerkat
When I'm not playing Silver Power Ranger, I'm a
Reply #481 on:
July 23, 2010, 11:32:24 PM »
Nabbed a windscreen and fairing from an S2R off here (thanks, corey) and am looking to slap it on my bike with a little modification. The fairing has a gloss factory finish now and my 620 is Dark. I'd like to knock the gloss finish off and rattle can a clear matte finish to have it blend a little better. So after 30+ pages of tips, here's my plan...
Careful 400 just to knock off the gloss finish. A good cleaning and allow to dry followed by 3 or 4 coats of matte clear with drying time between coats. Any suggestions for improvement?
I figure worst case scenario, I end up sending it off for a professional black matte treatment but I kind of like the tangerine if I can get the finish to match a little better. Of course that may change when it's actually on the bike and out of the garage.
'07 S2R1K
'09 Daytona 675
'03 620 Dark-Sold 03/26/2011
mojo
'99 M900S
Reply #482 on:
July 24, 2010, 05:06:25 AM »
400 grit might be a little coarse to clear over. It's fine if you are priming over it, but I'd do my final sanding with 600 grit if you are just clearing over the black. And be careful not to sand through the black basecoat otherwise you will be redoing that too. If you see ANY black on the sandpaper, stop sanding.
Some people are like slinky's. They serve absolutely no purpose, but they always bring a smile to your face when you push them down the stairs.
scott_araujo
Reply #483 on:
July 24, 2010, 10:36:33 AM »
FYI, the Dark black has lots of little metal flecks in it. If the gloss black doesn't it may not match after the flat clear.
DupliColor T090 Truck & SUV Universal Black followed by Krylon flat clear is a pretty good match and has held up well on my front fender over a season. These paints are easy to find and inexpensive. Try it on a piece of scrap first and see what you think. Or maybe just a light dusting of silver over the sanded black and then a flat clear. I think someone did sliver dusting over black a few pages back in this thread and it looked pretty good.
Scott
Meerkat
Reply #484 on:
July 24, 2010, 10:42:39 AM »
Some might call me crazy...the fairing is off a tangerine S2R, so it's gonna stick out like sore thumb. I like the tangerine, but the finishes look bad together. Hell, it may all look bad together when I get it done but as you said the Krylon flat clear is cheap so I thought I'd give it a try.
'07 S2R1K
'09 Daytona 675
Enjoying the ride
Reply #485 on:
July 24, 2010, 01:22:27 PM »
Hey Nate,
Congrats before everything else.
Now to bussiness, I've got a CF rear fender, as you might know, here in the tropics the Sun is relentless on any type of finish.
Can you recommend any UV clear for it? The guys at the paint shop wont touch it unless I give them precise instructions; CF down here is very very exotic...
Tks and enjoy the new stage in life...
Reply #486 on:
July 27, 2010, 04:28:41 PM »
Quote from: Darkmonster620 on July 24, 2010, 01:22:27 PM
Hey Nate,
Tell them to sand it with 600 wet and clear with the highest quality clear they can buy.
You will all of a sudden see millions of pinholes.
The next step is what gets time consuming...
you have to fill every one with a brush after re-sanding.
Then you sand flat and re-clear.
Or you can buy a new one and have it cleared before you install it.
The new part will have fewer pinholes because the epoxy resin hasn't degraded yet.
mojo
'99 M900S
Reply #487 on:
July 28, 2010, 01:18:10 AM »
Quote
...and then you will go crosseyed. Ask me how I know.
It's amazing how many flaws you will find in a CF piece.
Enjoying the ride
Reply #488 on:
July 28, 2010, 01:38:21 PM »
Quote from: mojo on July 28, 2010, 01:18:10 AM
How do you know???
You said to ask...
mojo
'99 M900S
Reply #489 on:
July 28, 2010, 02:27:24 PM »
Smartass
Enjoying the ride
Reply #490 on:
July 28, 2010, 03:15:26 PM »
Hey, I follow instructions...
Reply #491 on:
August 13, 2010, 11:43:24 PM »
G'day DP.
I'm not sure if someone has covered this.
A friend had his Superlight frame powder coated and it looked great. I thought I may get my frame powder coated with my wheels in the future. Both have paint that is servicable but will need a freshen up in a few years. When I asked some guys who weld for a living about this they said not to powder coat Chromemoly (spelling?) as the heat run thru the frame anneals the welds with that material. They said to have it painted instead.
Do you know if this is true?
Ddan
Some of my best friends are whores
Reply #492 on:
August 14, 2010, 01:24:08 AM »
I'd be very surprised if the powder coating got anyhwere near hot enough to anneal the frame, and FWIW, it's probably not chrome-moly
1992 900 SS,
currently a pile of parts.
Now running
flogged successfully
NHMS 12 customized. Twice. T3 too.
Ducati Monster Forum at
www.ducatimonsterforum.org
Reply #493 on:
August 14, 2010, 01:54:45 AM »
Quote from: koko64 on August 13, 2010, 11:43:24 PM
G'day DP.
Quote from: Dan on August 14, 2010, 01:24:08 AM
The newer frames are indeed mild steel.
The problem with powder coaters, notice I didn't say coating, is in the way they remove old material. Many will put a part in the oven and set the temp at some ridiculous number like 800 degrees to burn off any coating then blast and recoat.
Those temps will change the structure of steel, but not necessarily for the worse.
The temp of the oven for curing powder is about 350, and I wouldn't worry about that at all.
Reply #494 on:
August 14, 2010, 12:05:24 PM »
Thanks heaps DP.
32
33
34
35
67
