September 01, 2024, 07:21:27 AM
DIY Painting Tips
33
34
35
36
67
Topic: DIY Painting Tips (Read 398897 times)
S2R 800 '07
Re: DIY Painting Tips
Reply #495 on:
August 19, 2010, 01:33:56 AM »
I'm redoing my painted beer tray.
It has adhesive spray, red spray, vinyl stripes and the clear coates.
There are some scratches from bag straps - down to bare plastic.
Must it all come off to start over or can I do individual spots?
Reply #496 on:
August 19, 2010, 02:42:31 PM »
Quote from: stopintime on August 19, 2010, 01:33:56 AM
There are a couple of things to consider.
Over all film thickness is the major factor along with what your next scheme will be.
Do you have any idea the film thickness of what is already there, and what do you want to 'see' when it's re-done?
S2R 800 '07
Reply #497 on:
August 19, 2010, 11:29:37 PM »
Oh... there's a lot of rattle can paint on there now.
My first thought was that the adhesive coat, which has to go on the bare plastic in some small parts, would conflict with the paint which is already there.
I want to start with adhesive and I might as well strip it all down - then I'll have a layer of white, because the red was hard to get right on top of black plastic. Red doesn't cover well I guess.
Good thing about the white is that then I'll be able to have painted white stripes instead of the vinyl.
Ok with you DP?
Reply #498 on:
August 20, 2010, 12:40:28 AM »
Quote from: stopintime on August 19, 2010, 11:29:37 PM
Ok with you DP?
Th adhesion promoter shouldn't bother the color that's there.
How are you planning on stripping it?
Plastics don't like stripper.
...and yes a coat of white will make the job go much faster as you don't need as much red to cover...it will probably look like a different color.
S2R 800 '07
Reply #499 on:
August 20, 2010, 09:51:37 AM »
I like strippers
But I won't pay them to strip my plastic.
My plan is to sand it down by hand. I think I'll do the whole tray - it'll give me a better end result.
Reply #500 on:
August 20, 2010, 11:31:21 AM »
Quote from: stopintime on August 20, 2010, 09:51:37 AM
I like strippers
It will indeed.
Good luck with it.
scott_araujo
Reply #501 on:
August 20, 2010, 09:26:27 PM »
Stopintime, do you just want to start with a fresh one? I think I've got one and my Ducati is gone. You're welcome to it. It's off an '03 800 Dark.
Scott
S2R 800 '07
Reply #502 on:
August 20, 2010, 09:38:36 PM »
Quote from: scott_araujo on August 20, 2010, 09:26:27 PM
Scott
Thank you Scott
As I remember, cutting, grinding and sanding was the worst part of this job. That's why I'm thinking about redoing, but....
I snapped one of the four bolts, so it would be nice to get another though.
Maybe I'll get back to you.
BTW: your bike is gone....... was this approved by us?
bunnyman
Furry and IZ_
Reply #503 on:
August 22, 2010, 04:51:52 AM »
Was in Autozone on Friday, and I found a Rustoleum metallic textured paint that looks like a dead-ringer for Dark; just add matte clear.
Dammit!!! I still smell like Cotton Candy!!!
scott_araujo
Reply #504 on:
August 22, 2010, 11:21:46 AM »
Quote from: stopintime on August 20, 2010, 09:38:36 PM
Forcibly taken by an old lady with a BMW
S2R 800 '07
Reply #505 on:
August 22, 2010, 12:17:18 PM »
Quote from: scott_araujo on August 22, 2010, 11:21:46 AM
Sorry I asked - I had already heard, but didn't connect. Still too bad.
killerpenguin
Reply #506 on:
August 27, 2010, 08:44:41 PM »
i have a question. how hard is it to paint a monster frame? I'm talking about like taking a fully assembled bike a 2000 m750 taking it apart and painting the frame or any easier method. thanks a lot
http://www.facebook.com/home.php?#
!/photo.php?pid=31026669&id=1187070462
mojo
'99 M900S
Reply #507 on:
August 28, 2010, 01:09:36 AM »
Painting the frame won't be hard, it's just the disassembly that will take all the time.
Some people are like slinky's. They serve absolutely no purpose, but they always bring a smile to your face when you push them down the stairs.
Reply #508 on:
August 28, 2010, 01:20:19 AM »
Quote from: mojo on August 28, 2010, 01:09:36 AM
Actually a frame is a fairly difficult shoot.
A piece of tubing requires at least 4 passes, if not more, for good coverage/smooth appearance. Try getting the correct angle inside a trellis frame.
Most people choose powder for frames.
Reply #509 on:
August 28, 2010, 01:36:02 AM »
I had mine painted not PC'd. They said something like 50% of the paint was wasted. which sucked as it was a custom mix to match the PPG Ducati color.
33
34
35
36
67
