January 09, 2025, 06:15:26 AM
Please Help
DIY Painting Tips
34
35
36
37
67
Topic: DIY Painting Tips (Read 414608 times)
Re: DIY Painting Tips
Reply #510 on:
August 28, 2010, 02:01:35 AM »
Quote from: Raux on August 28, 2010, 01:36:02 AM
I had mine painted not PC'd. They said something like 50% of the paint was wasted. which sucked as it was a custom mix to match the PPG Ducati color.
Yup...
it ends up on the booth floor and in the filters.
killerpenguin
Reply #511 on:
August 28, 2010, 11:44:57 AM »
Could you guys give Me an estimate on the time involved in disassembling the bike to seperate the frame??
http://www.facebook.com/home.php?#
!/photo.php?pid=31026669&id=1187070462
Reply #512 on:
August 28, 2010, 11:52:58 AM »
Quote from: killerpenguin on August 28, 2010, 11:44:57 AM
doing it yourself?
1-2 weekends if you have all the right tools
Gimpy
Not quite a
Reply #513 on:
August 29, 2010, 08:18:15 PM »
Personally, I'd take a little longer, and take my time so that it went back together more smoothly. Document everything, label everything, and take pictures of everything. I'm always so surprised how much I can forget over the course of a few weekends. YMMV I'm sure there are folks that could put everything back from memory. But I sure can't.
2001 M900 Dark
Enjoying the ride
Reply #514 on:
October 01, 2010, 02:10:48 PM »
hey humorless dp,
can spray the underside of the dss with the thing they use to cover p'up beds? is rusting in some parts and will take off bike to repaint and wanted some added protection.
still undecided on what finish to give the dss, either polish/clear the steel or paint it 'black chrome' ... but underside needs the extra protection any way i go ...
Reply #515 on:
October 01, 2010, 02:20:44 PM »
Quote from: Darkmonster620 on October 01, 2010, 02:10:48 PM
hey humorless dp,
Sure...why not?
I'd sandblast if you have rust/prime/paint then use the bedliner stuff.
Enjoying the ride
Reply #516 on:
October 01, 2010, 02:24:00 PM »
Quote from: humorless dp on October 01, 2010, 02:20:44 PM
Sure...why not?
thanks ... would you then recommend polishing it or going "black chrome"? i plan on applying it on the underside and on the little curve the dss makes on the sides so that when i put in the rear stand doesn't scratch the sides or should i take the opportunity to install spools?
Reply #517 on:
October 01, 2010, 03:05:56 PM »
Quote from: Darkmonster620 on October 01, 2010, 02:24:00 PM
My take on polishing and then clearing bare steel is it isn't a sound process.
You would need to etch the steel to get good adhesion and that would ruin the polishing with discoloration.
If the black chrome uses a standard paint process meaning blast/prime/paint I'd suggest that.
Enjoying the ride
Reply #518 on:
October 01, 2010, 04:52:06 PM »
Quote from: humorless dp on October 01, 2010, 03:05:56 PM
then black chrome will be ...
S2daRk
Reply #519 on:
October 07, 2010, 06:43:56 PM »
I'd like to put a coat of clear on my CF parts to keep them from fading.
Does anyone have experience with the U-POL 1K UV resistant aerosol?
Do you think the 2K clearcoat aerosols would be any better?
mojo
'99 M900S
Reply #520 on:
October 08, 2010, 02:45:18 AM »
If you have access to the 2K, I'd use that. It will give you better chemical resistance, and durability.
Some people are like slinky's. They serve absolutely no purpose, but they always bring a smile to your face when you push them down the stairs.
Reply #521 on:
October 08, 2010, 04:24:35 AM »
Quote from: mojo on October 08, 2010, 02:45:18 AM
What he said...
lazylightnin717
Reply #522 on:
December 06, 2010, 07:14:51 AM »
DP: I plan on repainting my rearsets with a PPG urethane.
First and foremost: What would be the best way to prepare them? Looks like they were painted from the factory and are starting to oxidize. Paint stripper? Bead blast? Obviously clean well....
Will I need to prime the surface or is the paint a direct spray and play?
Comes a time
Says don't you see
Gotta' make it somehow
Reply #523 on:
December 06, 2010, 12:47:27 PM »
Quote from: lazylightnin717 on December 06, 2010, 07:14:51 AM
Best, and fastest way...
wash with solvent to remove road grime, bead blast (blow off dust, don't touch with bare hands), epoxy prime with PPG DP primer, and shoot wet on wet following label directions. PPG urethanes, I'm assuming you're using DCC, require primers.
HTH
lazylightnin717
Reply #524 on:
December 06, 2010, 06:48:46 PM »
Welllllll..... I'm not sure what DCC is. I can tell you that the ratio we have been using is 8:6:1 and we've been applying it directly to steel. Would Vari-prime be an acceptable primer?
On a side note: I'm having some issues getting the large rubber grommets out of the rearsets. Is there any easy way of removing them? Will bead blasting them pregnant dog them up?
Comes a time
Says don't you see
34
35
36
37
67
