DIY Painting Tips
Started by ducpainter, January 27, 2008, 08:36:03 AM
804monster
Nate
what base and clear products do you use when spraying a "dark" finish?
Quote from: 804monster on June 01, 2008, 04:26:32 PM
Nate
I had a dark scanned and used a PPG clear. The metallic appearance isn't perfect. The flat finish screws with the camera.
The PPG flat clear is DCU 2060.
It's a really nice appearance but it has a short shelf life.
Now I use DCU 2021 and SU 4985 flattener at the eggshell ratio. I don't have it off the top of my head
804monster
Quote from: 804monster on June 03, 2008, 07:20:35 PM
I hate painting dark
not my fave either...
the biggest issue is metallic presence with the flat clear.
I spent two days tinting a silver dark because the scan was so bad.
What's going on in here? ;)
How did I miss this? :P
Quote from: red baron on June 08, 2008, 06:23:34 PM
Just not payin' attention I guess.   ;D
errazor
Hi all, I have a smal scratch on my red frame. Is there a way to touch up that?
76 SUZUKI GT 100,  88 YAMAHA TDR 250,  07 DUCATI S2R 1000.
clittelm750
Quote from: DJ on May 07, 2008, 09:58:44 AM
Hi DucPainter!
Yep, planning on finally tearing the ol' girl down to the bare metal this summer and getting her all purty. She runs like a demon, now time to cleaner her back up and make her look as good as she sounds. ;)
I picked up a 30gal air compressor and two paint guns recently (large and small) but I'm a total newb with painting so will definitely be picking yer brain in the next few months! 8)
dj
Im planning on doing the same thing! ... But i'm wiating to the Winter months .. Up here in Maine we need to enjoy the weather while we got it!!
for long you live and high you fly but only if you ride the tide
clittelm750
What's involved in Painting Wheels .. My gut tells me a GOOD CLEANING, then spray em.  I was going to wait till the winter months when I do my frame, but if Ducpainter tells me its a weekend project then maybe, just maybe, I'll tackle it next rainy weekend!!
Quote from: clittelm750 on June 10, 2008, 11:00:32 AM
Cleaning is the key to any paintwork. It's the first step.
If you shortcut the basics the job will basically   ;D   suck
Then you have to sand...and treat any bare aluminum.
Then a primer...scuff... and paint.
The work can be done in a weekend, but the paint will be too soft to mount tires for several days under optimal drying conditions.
clittelm750
Alright so maybe not a weekend thing .. unless its a three day rainy crappy weekend followed by rainy days .. I can't drive the car to work on a sunny day without kicking myself in the pants all the way home ... so, back to the point at hand ...  I remove the wheels, clean the crap out of them .. what do I treat the aluminum with? (I've got 58K miles on those rims so I'm sure there is some Alum. showing somewhere!) .. should I "scuff" before the primer? .. What grit do I "Scuff" with? I just want a glossy Black (from the gold) how many caots am I looking at?  I am not looking for any show bike or anything but don't want people to look and say nice "Krylon touch Buddy" .. that being said, should a rattle can do the trick?!
And my last question ... Should I capitalize on my next tire change and do it with the rubber off? or just tape and spray?
Quote from: clittelm750 on June 11, 2008, 09:48:46 AM
Sand with 400 dry...use a scotch-brite in the areas you can't effectively sand with paper.
Clean again to remove sanding dust. You can use a post sanding cleaner.
Go to a PBE store and buy aluminum etching material. Follow the directions on the label.
Spot prime the treated areas...you don't need to do the entire wheel.
Scuff the primed areas smooth with 400 dry.
If you want a rattle can job...go for it. I don't recommend rattle can products.
If you want to mask the tires...go for it. That's not how I do it.
Quote from: ducpainter on June 11, 2008, 10:30:45 AM
one tip
a buddy of mine painted a wheel wit hthe tire on -- he deflated it and broke the bead, then taped the tire to get paint on the full lip.  painted, waited 2-3 days for it to dry then rebeaded the wheel and reinflated.
clittelm750
Hmmmm ..... Anyone have some black rims they wanna sell me cheap!  ??? ;D
804monster
thanks for your advice nate. i used a two stage process and, after some test panels, got the dark down pat. i still loath it though.
