September 01, 2024, 09:18:19 AM
DIY Painting Tips
43
44
45
46
67
Topic: DIY Painting Tips (Read 398939 times)
Ddan
Some of my best friends are whores
Re: DIY Painting Tips
Reply #645 on:
June 29, 2012, 03:58:17 PM »
Quote from: ducpainter on June 29, 2012, 03:34:00 PM
I'm pretty sure all rattle can stuff needs 7 days.
You realize you could end this pain.
Yes, I do. I'm stubborn, in case you hadn't noticed
My plan now is to chemically strip the paint, clean and sand whatever is left, and repaint. I'm gonna try two coats of paint within the two hour window they recommend, and then the clear also within the two hours. What could go wrong?
1992 900 SS,
currently a pile of parts.
Now running
flogged successfully
NHMS 12 customized. Twice. T3 too.
Ducati Monster Forum at
www.ducatimonsterforum.org
Reply #646 on:
June 29, 2012, 04:00:23 PM »
Quote from: Peggy on June 29, 2012, 03:58:17 PM
You...
stubborn?
suzyj
Does my bum look big on this?
Reply #647 on:
June 30, 2012, 11:45:28 PM »
Quote from: Peggy on June 29, 2012, 12:41:50 PM
It's peeling off in sheets. Is this still from the original non-cured problem, or am I doing something else wrong?
Many paints have minimum recoat times and maximum times as well.
When you left the initial coat for five days and then recoated, the solvent in the new coat destroyed the original coat, rather than blending in with it.
With most paints, you don't wait more than ~12 hours between coats.
J5
I'm here to fix zee fridge
Reply #648 on:
June 30, 2012, 11:58:23 PM »
from experience
wheels that have sand casting are a PITA to strip as the paint sticks in all the holes
sand down and paint , and as mentioned above paint within hours
i prob wouldnt suggest 2pac over rattle can
Ddan
Reply #649 on:
July 01, 2012, 12:43:51 AM »
Quote from: suzyj on June 30, 2012, 11:45:28 PM
The can spec'd recoat within 2 hrs. or after 48. I think because the original coats went on with low temps and high humidity the paint never stuck. When it started peeling I could smell solvents so I'm guessing it never cured right.
Quote from: J5 on June 30, 2012, 11:58:23 PM
from experience
Too late
I wound up stripping to bare metal. A brass brush worked pretty well to get the original coat off once it had been softened enough by the stripper.
I recoated with the adhesion promoter, primer, color and clear. This morning it looks pretty good, time will tell how it cures.
Nate didn't like the idea of the 2-part clear over enamel either but it seems to be doing OK on the frame I finished earlier...
Last Edit: July 01, 2012, 12:52:52 AM by Peggy
1992 900 SS,
Now running
Reply #650 on:
July 01, 2012, 01:38:20 AM »
The reason I don't like 2K over synthetic enamel is the enamel takes a long time for solvents to evaporate due to the quality of the solvent. The solvents used in bc/cc systems are better matched for the wet on wet process.
2K paints 'skin', or partial cure, quickly and trap the solvents which will affect adhesion. They don't fully cure for 90 days. You can make a fingernail mark in rattle can for a month due to the slow evaporation rate of the low quality solvents. I'm still skeptical about his process.
Had Peggy used more compatible materials his wet on wet on wet job would work better.
BTW...most local PBE stores will sell you any grade of material in an aerosol can...either 1K or 2K...probly not in Cali.
You don't need to use Rustoleum just to get a rattle can.
Ddan
Reply #651 on:
July 01, 2012, 01:43:35 AM »
Quote from: ducpainter on July 01, 2012, 01:38:20 AM
I didn't know this...
1992 900 SS,
Now running
Reply #652 on:
July 01, 2012, 01:53:57 AM »
Quote from: Peggy on July 01, 2012, 01:43:35 AM
It's why you ask questions...
first.
Ddan
Reply #653 on:
July 01, 2012, 05:08:07 AM »
Quote from: ducpainter on July 01, 2012, 01:53:57 AM
first.
But that takes all the adventure out of it
1992 900 SS,
Now running
Reply #654 on:
July 01, 2012, 05:15:08 AM »
Quote from: Peggy on July 01, 2012, 05:08:07 AM
frustration does not equal adventure...
Ddan
Reply #655 on:
July 01, 2012, 08:27:32 AM »
Quote from: ducpainter on July 01, 2012, 05:15:08 AM
Practice is when things go well, experience is when they don't
1992 900 SS,
Now running
Reply #656 on:
July 01, 2012, 08:39:04 AM »
Quote from: Peggy on July 01, 2012, 08:27:32 AM
Experience is something you don't get until just after you need it.
TitanMonsterS4R
Reply #657 on:
July 01, 2012, 01:14:22 PM »
Rattle canned a pair of gold anodized CRG levers and Rizoma reservoirs with Dupli-Color Engine enamel. Now looking to return to their original state. Can I just soak them in paint thinner to remove the rattle can black without damaging the anodized gold?
Reply #658 on:
July 01, 2012, 02:10:13 PM »
Quote from: MonstaS2R on July 01, 2012, 01:14:22 PM
Probably.
Thinner won't hurt anodizing.
Reply #659 on:
July 01, 2012, 04:20:07 PM »
This is making me think twice about painting my wheels in winter, or getting too fancy with them.
I will lightly sand, prepsol, paint with mag/gold canned wheel paint (kind of close to the Ducati silver/gold), and leave to cure in the hot aussie sun,
Or
Just pay the man!
DP, pity I'm so far away. It's better for me to tune a few bikes and use the money to pay a pro. I'm just about done DIY painting after all the half assed paintwork I've done in my racing years.
43
44
45
46
67
