September 01, 2024, 07:23:56 AM
Please Help
DIY Painting Tips
48
49
50
51
67
Topic: DIY Painting Tips (Read 398907 times)
JohnEE
Why not
Re: DIY Painting Tips
Reply #720 on:
February 03, 2013, 04:48:14 AM »
Would i run into any problems using Black BBQ spray paint to paint an oil cooler radiator?
08' S2R 1000
Reply #721 on:
February 03, 2013, 04:52:12 AM »
Quote from: JohnEE on February 03, 2013, 04:48:14 AM
Probably not.
Just make sure you get it clean and scuff what you can with a scotch-brite.
Enjoying the ride
Reply #722 on:
April 14, 2013, 09:00:02 AM »
dp,
got a guy that wants to paint black his passenser pegs[Honda CBR250R], they are really shinny . .
340 > 600 > brillo > primer > colour ? Just want to be sure, will be able to use a loaned compressor/paint gun
Reply #723 on:
April 14, 2013, 09:03:26 AM »
Are the shiny anodized, or shiny paint?
Enjoying the ride
Reply #724 on:
April 14, 2013, 09:13:40 AM »
Quote from: ducpainter on April 14, 2013, 09:03:26 AM
seems shinny paint
Reply #725 on:
April 14, 2013, 09:30:24 AM »
You don't need to prime if you have no bare metal.
400 or 600 dry and paint.
Enjoying the ride
Reply #726 on:
April 14, 2013, 09:43:52 AM »
Quote from: ducpainter on April 14, 2013, 09:30:24 AM
ok, just confirming, what measure should I use for the paint? how muxh paint/'diluter'
Reply #727 on:
April 14, 2013, 09:47:26 AM »
Quote from: Darkmonster620 on April 14, 2013, 09:43:52 AM
How would I know? It depends on the brand and product.
What does the can say? Are you using activator?
Enjoying the ride
Reply #728 on:
April 14, 2013, 09:50:15 AM »
Quote from: ducpainter on April 14, 2013, 09:47:26 AM
1:4 on a piece of masking tape on the color[dupont] and the other is glasurit
Reply #729 on:
April 14, 2013, 09:53:41 AM »
Quote from: Darkmonster620 on April 14, 2013, 09:50:15 AM
The DuPont uses a combination activator/reducer at a 4:1 ratio...4 parts color...1 part activator.
The Glasurit...no clue.
Enjoying the ride
Reply #730 on:
April 14, 2013, 09:56:47 AM »
Quote from: ducpainter on April 14, 2013, 09:53:41 AM
ok, thanks, gonna try
will post results during week
Langanobob
Reply #731 on:
April 15, 2013, 03:47:52 PM »
Quote from: ducpainter on January 15, 2013, 05:16:28 PM
Red
is
expensive.
Look into PPG Omni...it's their 'value' line.
Take the part you want to match and check the stock chips or some foreign car colors as a comparison and pick something close.
Joshua,
When it comes to painting I'm many laps behind DP but I've had good luck with DuPont Nason, which is also DuPont's value line. I've also tried matching stock and foreign car color chips but the ones they had were pretty small and hard to compare due to the small chip size. when I got the bike done it was OK but not quite the red that I wanted. Close though. Red is expensive but reasonably good quality paint isn't cheap in any color. You'll forget how much the paint costs once it's done. Also, I've had good luck with pricing at auto paint stores. Sometimes they will give you a much better price, all you have to do is ask. Stick with red, don't go to a color you don't really want just to save some money.
Last Edit: April 15, 2013, 03:51:46 PM by Langanobob
ChrisK
Reply #732 on:
April 23, 2013, 09:55:02 AM »
Ducpainter, I'm getting ready to paint my project bike. Thinking about doing a dark grey tank with a white stripe. What's the general order of steps I should take? Primer, all grey, then mask it off and paint white stripe? Or primer, all white, then mask it off and paint grey over the white? Thanks!
1998 M900
2007 CBR600RR Track Bike
1980 Lambretta Moped
Supra Boats enthusiast
Reply #733 on:
April 23, 2013, 04:46:38 PM »
Quote from: ChrisK on April 23, 2013, 09:55:02 AM
You can either paint the white, mask, and then grey...
or the reverse.
It's less masking if you paint the white first.
You don't need to paint the entire tank white first if you decide to do it that way...just wide enough to cover your stripe.
If you're using rattle cans make sure you give it enough dry time to avoid lifting.
ChrisK
Reply #734 on:
April 24, 2013, 08:33:20 AM »
Great, thank you very much. I'm assuming "lifting" means the paint lifting as you pull the tape away, make sense.
1998 M900
48
49
50
51
67
