November 09, 2024, 12:31:09 AM
DIY Painting Tips
49
50
51
52
67
Topic: DIY Painting Tips (Read 408038 times)
Re: DIY Painting Tips
Reply #735 on:
April 25, 2013, 05:53:47 PM »
Quote from: ChrisK on April 24, 2013, 08:33:20 AM
Great, thank you very much. I'm assuming "lifting" means the paint lifting as you pull the tape away, make sense.
Actually, by lifting I mean wrinkling and lifting from the second color softening it.
Most rattle can products require at least a week before recoating. They also require a light scuffing for adhesion.
uclabiker06
"The time you enjoy wasting isn't wasted"
Reply #736 on:
May 10, 2013, 08:57:05 PM »
Wow, cool thread...that was fun. Anyways, DP thanks again for the rubbing compound recommendation. Can I use the 3M rubbing compound on my carbon fiber pipes instead of the denaturated alcohol? Figured its mild enough. The C/F on my pipes hasn't clouded up yet but definately oxidized...just like the swingarm.
Last Edit: May 10, 2013, 09:52:42 PM by uclabiker06
2006 S2R
2009 Smart
Reply #737 on:
May 11, 2013, 03:10:30 AM »
Try it.
If the weave is heavy, or there are pinholes it might be hard to get it all off.
Enjoying the ride
Reply #738 on:
May 11, 2013, 04:54:29 AM »
these are the rear foot rest of the Honda CBR250R
Honda CBR250R pass rear set 2
these mirrors have simply taken my patience to the limit, sanded/cleaned them about 4 times, always the same result, with the same side mirror, have the front & rear fenders off, the headlight & rear fender supports off to be painted black also . . . those parts are aluminium
Sachs MadAss125 mirrors
uclabiker06
Reply #739 on:
May 11, 2013, 09:36:33 AM »
Got it.
2006 S2R
2009 Smart
SpikeC
Spike in PDX
Reply #740 on:
May 11, 2013, 10:18:04 AM »
Looks like you need to try a different type of paint on those mirror heads!
Spike Cornelius
PDX
2008 Bimota DB5R woo-Hoo!
1965 T100SC
Enjoying the ride
Reply #741 on:
May 11, 2013, 06:45:02 PM »
Quote from: SpikeC on May 11, 2013, 10:18:04 AM
I was painting them to make the bike 'whole' . . . one was 'black' the other was 'dark grey' . . . please note how I wrote it . . they stay as they are . . . not making much $$ from this job . . .
Reply #742 on:
May 12, 2013, 02:39:25 AM »
One of the mirrors came out fine, and one created issues.
It isn't the paint.
Enjoying the ride
Reply #743 on:
May 12, 2013, 10:18:10 AM »
Here is the Honda CBR250R that I painted the rear foot rests . . . Now the guy wants to paint the front ones !!!
Same, all black, I told him not to make it ALL black, let's leave some silver, what say you?
Reply #744 on:
May 12, 2013, 11:23:10 AM »
His bike, customer's always right. Clearly not a safety issue. Paint 'em.
joshuajcrouch
Reply #745 on:
June 01, 2013, 10:17:24 AM »
Well I am an idiot and dropped my bike coming in for a stop. Turning and braking was a bad combination and I tipped over.
The handlebar hit the gas tank and cracked the clear coat. Can't tell if the base coat is cracked. As far as I can tell the gas tank itself is not dented or anything.
My friend helped me with the clear coat. Its only a month old and is an automotive grade. Was wondering what your recommendation is for fixing. Should I lightly sand the area and respray just this spot?
Reply #746 on:
June 01, 2013, 11:41:42 AM »
Quote from: joshuajcrouch on June 01, 2013, 10:17:24 AM
If it's cracked, you need to sand to the bottom of the crack or it will 'telegraph. This will inevitably get in to the color. You'll need to prime, spot in, and re-clear.
That color is going to be tough to spot in due to the heavy metallic. Good luck.
SpikeC
Spike in PDX
Reply #747 on:
June 01, 2013, 02:29:05 PM »
If it was me I would just dap a spot of jewelers epoxy on the spot, it is very clear and will wick into the crack.
Spike Cornelius
PDX
1965 T100SC
joshuajcrouch
Reply #748 on:
June 01, 2013, 11:40:06 PM »
Quote from: ducpainter on June 01, 2013, 11:41:42 AM
Thanks for the advice guys. I tried just re-clearing and you were right. Eventually the pressure around the crack just pushed back up, even though there was a few coats of new clear on top.
I sanded the area down to the primer and now I am just playing the blending game, which isn't very fun.
suzyj
Does my bum look big on this?
Reply #749 on:
June 02, 2013, 04:21:52 AM »
It's not too late to paint it RED.
Sorry, I had a couple of glasses with dinner.
49
50
51
52
67
