September 01, 2024, 07:22:07 AM
DIY Painting Tips
52
53
54
55
67
Topic: DIY Painting Tips (Read 398899 times)
ChrisK
Re: DIY Painting Tips
Reply #780 on:
June 27, 2013, 01:14:16 PM »
To fix a dent, likely with bondo.
1998 M900
2007 CBR600RR Track Bike
1980 Lambretta Moped
Supra Boats enthusiast
Reply #781 on:
June 27, 2013, 01:27:55 PM »
So you don't want to strip the tank completely. That's good, because the average DIYer can't do as much to prevent corrosion as the factory.
To remove paint for adhesion of filler use a disc sander...24-36 grit.
ChrisK
Reply #782 on:
June 27, 2013, 01:59:45 PM »
What do you mean I don't want to strip the tank completely? Doesn't the use of bondo require bare metal?
1998 M900
Reply #783 on:
June 27, 2013, 05:34:18 PM »
Quote from: ChrisK on June 27, 2013, 01:59:45 PM
Yes...but...
How big is this dent?
I guess syntax was wrong.
You don't need to strip the
entire
tank to repair a dent.
theoneillusion
Reply #784 on:
June 29, 2013, 07:31:21 AM »
I've read through much of this thread and I'm about to go nuts trying to find the paint that I'd like. Too much fluff in all of the manufacturers terminology.
I'd like to do a simple solid color paintjob on my plastic S4RS tank. I know I will need to use adhesion promoter in a few spots that I sanded down to bare plastic and I'm ordering an LPH80 airbrush to go with my ROLAIR Bull compressor.
http://cdn.trendhunterstatic.com/thumbs/red-bull-helmet.jpeg
^This is the color scheme I'm attached to; an off-white of this shade and a similar red. I've been to a few websites and looked at the House of Kolor paint (because of the good word on it) and can't find a solid color similar to the off-white. What product should I use for this job (off-white, red, clear)? I would have never thought it so difficult to get some paint.
Thank you in advance for helping me save a few non-grey hairs.
Reply #785 on:
June 29, 2013, 04:14:26 PM »
Quote from: theoneillusion on June 29, 2013, 07:31:21 AM
If it was easy everyone would be a painter.
What materials are available to you locally?
You won't find that color on line.
ChrisK
Reply #786 on:
July 01, 2013, 05:37:23 AM »
How much paint is enough paint? I know this probably changes as you go between brands, but if I'm painting just the tank and seat cowl, how much of that color do I need? Is a 1/2 pint enough? Whole pint? Quart?
1998 M900
Reply #787 on:
July 01, 2013, 05:49:45 AM »
Quote from: ChrisK on July 01, 2013, 05:37:23 AM
It probably more depends on your equipment.
A pint will be plenty as long as you have a uniform base to spray over.
If the color you choose is a good hider, and you have the right color base, 1/2 pint might suffice but that might not allow you to change the color of the underside, and it would suck to run out 1/2 way through the last coat.
ChrisK
Reply #788 on:
July 01, 2013, 05:54:07 AM »
Planning on going forest green, is black primer the right base? Also, was going to spray the underside of the tank black. Given these three variables and me using a harbor freight HVLP gun will I be good to go with a 1/2 pint? Correction: SHOULD I be good to go?
1998 M900
Reply #789 on:
July 01, 2013, 06:03:15 AM »
Quote from: ChrisK on July 01, 2013, 05:54:07 AM
Uniformity is more important than the actual color. That said, I'd go with a grey for your green because base color can affect perceived color depending on lots of factors.
Yes, you
should
be OK if nothing goes south on you.
theoneillusion
Reply #790 on:
July 01, 2013, 01:05:47 PM »
Quote from: ducpainter on June 29, 2013, 04:14:26 PM
Everyday my respect grows for those who have various trades I encounter.
I've got HOK and PPG available locally.
Reply #791 on:
July 01, 2013, 01:31:53 PM »
Quote from: theoneillusion on July 01, 2013, 01:05:47 PM
I would go into your PPG guy and ask to look at color chips.
Look at Porsche code 51A Cremeweiss, Mazda Marble White code A5M, BMW Pepper White code 850, and VW Harvest Moon code LB1M. All these are in the 2009 PPG chip book.
Ford used a cream color like that in the 70's, and I believe BMW or Mercedes had a very creamy white also. The problem you may encounter when looking for legacy colors is bc/cc availability.
The red will be much easier. Mazda had some reds very similar to what I saw in your link.
I think one of those will suit you.
theoneillusion
Reply #792 on:
July 02, 2013, 06:56:06 PM »
Quote from: ducpainter on July 01, 2013, 01:31:53 PM
Thank you! I'll drop by and check those out.
ChrisK
Reply #793 on:
July 22, 2013, 11:36:35 AM »
Two questions:
For spraying a matte clear, what's the process? Spray your color coats, then wetsand to a perfect surface and then spray the matte? There's nothing you can do to the matte after you've sprayed, correct?
Second, any chance you could post a pic of how you situate a tank for painting. In other words, what you set it on, what angle you have it at, etc. so that spraying it is as easy and efficient as possible.
1998 M900
Reply #794 on:
July 22, 2013, 12:57:16 PM »
Quote from: ChrisK on July 22, 2013, 11:36:35 AM
Two questions:
You shouldn't need to sand your base coat if you apply it properly. You can sand dust nibs but you'll need to reapply color. It is correct that you can't do anything to the clear.
I have a stand I made. It's nothing very special.
P2130034
by
nh_painter
, on Flickr
It orients the tank similarly to the way it sits on the bike. If you are painting the underside you can either do that first, or hang the tank by the hinge and do it all at once. I think hanging it is harder. It's tough to do a good job on a swinging target.
52
53
54
55
67
