September 01, 2024, 07:25:37 AM
DIY Painting Tips
54
55
56
57
67
Topic: DIY Painting Tips (Read 398917 times)
Re: DIY Painting Tips
Reply #810 on:
August 07, 2013, 07:47:45 AM »
Quote from: ChrisK on August 07, 2013, 06:18:39 AM
Planning on spraying matte clear and I also have black vinyl decals for the sides of the tank. Can I spray the clear over them? I know I could if it were gloss clear, but wasn't sure about matte.
Yes.
theoneillusion
Reply #811 on:
August 07, 2013, 05:29:41 PM »
Quote from: ducpainter on August 07, 2013, 02:59:17 AM
Yes...except I'd use 3 coats of surfacer. 100 scratches are pretty aggressive. The reason I recommend 100 is because you'll be there forever with anything finer. You could step up to 180/220 to finish to allow less primer build.
The MP 171 will 'handle' much differently reduced. Spray enough to just cover in one coat...don't use a heavy coat, but you want it smooth. Use urethane reducer for the temp you're working at. 50% is max and will depend on your gun whether you actually need that much.
Wait at least 30 minutes after you seal to allow the reducer to evaporate. You have a long window with the MP so you could even wait over night with no sanding necessary.
Good luck.
Make a donation to the forum...
http://www.ducatimonsterforum.org/index.php?topic=1241.0
Beautiful! I'll do all as directed. Back to sanding, I am.
Gimpy
Not quite a
Reply #812 on:
August 10, 2013, 12:01:46 PM »
Whoa!! That's a cool idea... Any pictures of what you are trying for? I don't have any paint projects coming. But I think my clutch is going bad, which means I need to drop the motor and powder coat the frame red. I'll just have to paint the tank as well.
2001 M900 Dark
Reply #813 on:
August 13, 2013, 04:42:30 AM »
Quote from: theoneillusion on August 07, 2013, 05:29:41 PM
Fingers worn out yet?
ChrisK
Reply #814 on:
August 13, 2013, 08:03:20 AM »
Ducpainter, I'm going to just transfer the questions I just asked you via e-mail to here, suppose this is the correct place to discuss this.
To catch interested parties up, I'm going to be using a waterborne paint for my project. DP has recommended PPG DCU-2060 as a good clear to get the matte finish I'm looking for. My question to DP is this: I've looking into the DCU-2060 and the PPG description kind of makes it sound like it's meant to be mixed with other clears. Regardless of this being true or not, is it still okay to use this as the only clear coat, to achieve that matte finish? Here is where I got the information:
http://www.tricitypaint.com/docs/P-217.pdf
Second question, if I spray Rustoleum brand primer, will it be okay to use the waterborne stuff over top of it? In other words, it won't cause lifting will it? Here is a link to the specific primer I'd be using:
http://www.grainger.com/Grainger/RUSTOLEUM-Filler-Primer-6PET4
Thanks
1998 M900
2007 CBR600RR Track Bike
1980 Lambretta Moped
Supra Boats enthusiast
ChrisK
Reply #815 on:
August 13, 2013, 08:05:48 AM »
He has also said that I'd need DCX-61 activator to work with the clear and a reducer for "the temps I'm working at"
1998 M900
Reply #816 on:
August 13, 2013, 08:19:46 AM »
Quote from: ChrisK on August 13, 2013, 08:03:20 AM
Thanks
Read the P sheet again... It says it
can
be blended with other clears, not that it
has
to be.
I have no experience with the brand of paint, or the brand of primer you want to use. I would use an activated primer too. I honestly can't say if you'll have problems.
Here's the thing...quality automotive materials are expensive...period. You sometimes can save money by using the major manufacturers value line. In the case of PPG it would be the Omni line of paints. They may offer a low gloss clear. If you stay within one brand, and quality level, for primer and clear often they'll use a common activator which saves money.
You can also buy a gloss modifier such as PPG SU-4985 which works in all clears and single stage colors. You would have to do a little experimenting to get the exact level you want.
When you choose a value line paint you may be giving up some of the desirable attributes of the top of the line products or it might just be the guarantee.
There is no one right choice. There are a ton of possibilities to have trouble.
ChrisK
Reply #817 on:
August 13, 2013, 08:22:02 AM »
Okay.
Another question I just thought of. I'm still planning on doing that racing stripe. Would I run into any problems using Dupli-Color "Paint Shop" paint over top of the waterborne stuff?
1998 M900
ChrisK
Reply #818 on:
August 13, 2013, 08:51:24 AM »
Don't address that last question, not going that route. lol
I'm just doing it the easy way, buying primer and clear from the same place I got the paint. Sorry for the hassle.
1998 M900
Reply #819 on:
August 13, 2013, 10:28:35 AM »
Quote from: ChrisK on August 13, 2013, 08:51:24 AM
Good call.
If you're going to stripe it I'd ask someone else about doing it over the water borne without clearing first.
The only info I have is that waterborne can be tough to get to dry without sufficient airflow. I have no info about tape times...etc.
ChrisK
Reply #820 on:
August 13, 2013, 10:34:59 AM »
I'll contact them about recommended tape and process.
I actually built a make-shift paint booth in my garage attic, complete with filter and fan. So airflow is actually pretty good, but I see your concern.
The paint I have has "no re-coat window" so I believe that means I have plenty of time to let it dry before I have to lay tape down.
1998 M900
Reply #821 on:
August 13, 2013, 01:25:00 PM »
Quote from: ChrisK on August 13, 2013, 10:34:59 AM
That is what no re-coat window means.
theoneillusion
Reply #822 on:
August 13, 2013, 02:54:25 PM »
Quote from: ducpainter on August 13, 2013, 04:42:30 AM
Haha
Not there just yet, but I'm taking my time and doing a little each day. You should have seen it, seems like every time I went to look at it there were more cracks. Want to do it right this go around.
Quote from: ChrisK on August 13, 2013, 08:22:02 AM
Okay.
I played around with that stuff and was less than impressed. The stuff is already thinned so you're not getting the quantity you think and the quality sure isn't there (from my humble less than amateur opinion).
ChrisK
Reply #823 on:
August 18, 2013, 07:10:28 PM »
DP, do you happen to know the dimensions of the stripes on the S4RS's?
1998 M900
Reply #824 on:
August 19, 2013, 02:30:56 AM »
Quote from: ChrisK on August 18, 2013, 07:10:28 PM
I don't know the exact number.
I just make the overall width the same as the hole in the top of the tank.
I make the narrow stripes 1/8".
54
55
56
57
67
