September 01, 2024, 09:24:05 AM
Please Help
DIY Painting Tips
61
62
63
64
67
Topic: DIY Painting Tips (Read 398967 times)
Re: DIY Painting Tips
Reply #915 on:
April 10, 2015, 01:48:19 PM »
Quote from: scaudill on April 10, 2015, 01:17:52 PM
Touchup frame paint for my '01 750 M. Metalized grey 291.601, is there a something available in a small container?
Thanks, Sterling
Color Rite 7580 Ducati Gray Metallic
scaudill
Reply #916 on:
April 10, 2015, 02:04:40 PM »
Thanks Howie, Placed my order.
Sterling
Reply #917 on:
April 10, 2015, 02:19:08 PM »
Not that I'm aware of.
Colorrite would be the best bet, but they don't list that color.
SpikeC
Spike in PDX
Reply #918 on:
April 12, 2015, 11:30:33 AM »
Quote from: SpikeC on December 24, 2014, 10:52:02 AM
Thanks for the tips, they say 2 medium wet coats, 15 to 25 minutes apart. my only concern is that the coating does not attack the decals.
OK, DP, i did the deed on my alloy tank with a foam roller. Rather than applying a light first coat, the roller held a lot of the finish and I ended up trying to roll out the drips and ended up with a healthy dose of orange peel! The finish cured really well, and the cleaner/primer did its job.
Now I need smooth it out a bit. I have some wet or dry paper from the auto shop, I'm sanding out a drip with 1500, and I have up to 2000.
Even with the weird texture it is looking pretty good! The tank decals survived nicely!
Spike Cornelius
PDX
2008 Bimota DB5R woo-Hoo!
1965 T100SC
Reply #919 on:
April 12, 2015, 03:57:14 PM »
Quote from: SpikeC on April 12, 2015, 11:30:33 AM
3M compound and a wool pad after the 2K grit.
Finish with a foam pad and a hand glaze.
You're kind of in uncharted territory. I've never sanded and buffed that stuff.
You could sand out the defects and try a single coat. Just 'unload' the roller on a different surface.
SpikeC
Spike in PDX
Reply #920 on:
April 12, 2015, 04:21:36 PM »
Thanks for all of your advice, DP! The Glisten PC from Por15 is the cats pajamas!
The polishing compound that I now have is some ancient Turtlewax Polishing compound and it is giving a soft satin finish, I need to just work it a bit, I think. As the tank is hand made and not exactaly perfect, I'm not going for a mirror finish, at least not yet!
All in all I'm having fun with this!
Last Edit: April 12, 2015, 04:26:12 PM by SpikeC
Spike Cornelius
PDX
1965 T100SC
Nibor
insanity far outweighs horsepower
Reply #921 on:
December 12, 2015, 03:39:32 AM »
Threw some VHT caliper paint at a few parts today. Followed the instructions on the can, multiple coats, 10min or so apart, then let it sit for a couple of hours before throwing it in the oven at 100*c for 1 hour.
Had some foil lining the oven trays to keep the marriage safe, but the paint has stuck to the foil at contact points. Did this happen because I baked too soon, needs to dry/cure longer before baking? No time was listed for resting before cooking.
Peel the foil off, some parts separated ok, other bits the paint stuck/came off. Will have to strip/prep/repaint, but I'd rather get it right this time.
Any tips?
Reply #922 on:
December 12, 2015, 04:16:09 AM »
You need to eliminate the contact points.
Nibor
Reply #923 on:
December 14, 2015, 01:03:38 AM »
Quote from: ducpainter on December 12, 2015, 04:16:09 AM
Challenge accepted.
Thanks mate!
Langanobob
Reply #924 on:
March 24, 2016, 08:12:52 PM »
I have an old steel Triumph tank that I sealed with Kreem a long time ago, before POR 15, Caswells and other stuff were invented. The Kreem has been coming loose and the tank is oozing fuel all over again. Just wondering what the best method might be for removing the old Kreem? If possible I'd like to save what I can of the exterior paint but it's not a requirement. I've thought about pouring epoxy remover in the tank and letting it set for awhile, then rinsing it with some prohibited chemical and rattling some rocks and nuts and bolts around inside for awhile. I'm hoping there's a better way but I'm guessing there probably isn't.
Thanks,
Bob
Enjoying the ride
Reply #925 on:
March 25, 2016, 06:36:44 AM »
Nibor, get some wire put the rack on the highest position and hang the calipers using the screw holes to pass wire . . . put either foil or foil covered tray on bottom . . contact points will be minimal and to retouch, a quick spray to said area and done . . .
Now, back to our regurarly scheduled programming
Langanobob
Reply #926 on:
March 25, 2016, 08:05:38 AM »
Also, I've baked a few paint jobs and never had trouble with sticking. Maybe try letting it cure longer before putting the heat to it. I did some unscientific tests awhile back and baking really improved the paint durability and scratch resistance (rattle can paint, I never tried baking real paint).
Reply #927 on:
March 25, 2016, 08:24:49 AM »
You could also try a heat gun to help the curing process before moving it into the oven.
Reply #928 on:
March 26, 2016, 04:59:44 AM »
Quote from: Langanobob on March 24, 2016, 08:12:52 PM
Thanks,
Bob
MEK will dissolve it.
It takes a lot of soaking and then flushing with fresh solvent. The MEK will destroy most materials you might use to seal things up.
I did a few and then stopped doing them. There isn't enough money to convince me to do another.
Langanobob
Reply #929 on:
March 28, 2016, 01:44:14 PM »
Thanks DP. I'll let you know how it turns out.
61
62
63
64
67
