February 05, 2025, 12:49:11 AM *
Author Topic: DesmoTimes Powercard  (Read 1435 times)
dklay
« on: September 07, 2009, 12:22:58 PM »
Anyone using one ? I've seen plenty of posts/ threads re. powercommanders, DP Ecu's, and Ecu flashing, etc.. but virtually nothing on the DT Powercard. Seems like a very reasonably priced solution for minor injection cleanup/ tuning. Any replies specifically in regard to an S2R800 (mine's '06) would be appreciated.
Mr Earl
2003 M800 Dark
« Reply #1 on: September 07, 2009, 02:59:54 PM »
I have the Techlusion TFI on my M800.  The TFI is similar to, but a little less adjustable than, the Powercard.  I picked it up new for $190.  It has made a remarkable difference in my bike's performance.  Let me reiterate: remarkable.  Even the exhaust tone is better, more powerful-sounding.  I believe that the 800 motors with the stock 5.9 ECU run too lean across the rpm range, and power is lost as a result.
Neither a PC nor a dyno is necessary for tuning the TFI or Powercard.  It's similar to setting up a carbureted motor.  No doubt a Power Commander can extract more performance, but I'm very happy with this TFI.  YMMV.
Leo Vince CF slip-ons, '01 SS900 fully adjustable Showa forks w/ST2 springs, rebuilt S4 shock w/Ohlins spring, 748 dog bone, Swatt clip-ons above the triple, Sargent seat, Duplicolor-Dark seat cowl, Rizoma grips, Techlusion TFI, SBK front fender, Evoluzione slave, BMC sport air filter, 14-tooth sprocket, Desmotimes caseguard, S2R side panels, Pantah belt covers, fake CRG LS mirrors, extra black zip-ties, right grip control imprint on tank, de-cannistered, Ducati Meccanica Bologna key ring
Triple J
« Reply #2 on: September 07, 2009, 04:08:06 PM »
I have one on my '04 Multistrada (Monstrada). It's a 1000DS engine, not closed loop. It helped when I added an exhaust system, by allowing me to add in a bit more fuel.
brad black
« Reply #3 on: September 09, 2009, 03:27:38 AM »
some stuff i've written about it. relates to the older style 1047ST, but the power card is a similar variation i believe.
http://www.bikeboy.org/s2rcateliminator.html - starts about half way thru.
http://www.bikeboy.org/800monstercamtiming.html
http://www.bikeboy.org/staintunetuningtechlusion.html
Brad The Bike Boy
dklay
« Reply #4 on: September 10, 2009, 12:02:53 PM »
thanks for the info....brad especially. your links were far more info than I was expecting to get. thanks.
« Reply #5 on: September 10, 2009, 03:48:59 PM »
hows it work in conjunction with an 02 sensor?
