Clutch handle nut?
Started by Mike Qube, September 10, 2009, 04:03:47 PM
Mike Qube
Anyone know what size the nut is that goes on the hollow bolt that holds the clutch handle on? Today I notice it was gone as that bolt was rising out. Now I know why there is a zip tie on the brake lever one.
rockaduc
Quote from: Mike Qube on September 10, 2009, 04:03:47 PM
Quote from: rockaduc on September 10, 2009, 04:31:54 PM
WHich bike?
he has a 97 M750...
You can buy the nut from the dealer. Check with Ducati Seattle or Commonwealth.
I don't know the size.
If you look at the remaining nut on the brake lever you will see it is a special nut, so you should get it from the dealer.  Add BCM to ducpainter's list if Ducati Seattle or Commonwealth don't have one in stock.  A wire tie through the pivot bolt will save you from this problem in the future.
Mike Qube
I just checked out the one on the brake lever, it's just a type of locknut. I believe I've seen them in an electrical supply place.
Quote from: Mike Qube on September 11, 2009, 04:18:47 AM
In metric sizes?
Mike Qube
Quote from: ducpainter on September 13, 2009, 11:25:34 AM
In metric sizes?
I ended up finding one at a place in Wakefield MA called "Metric Tool". I found out the type of nut, it is a Pal Nut. The Ducati dealer here wanted $8 for it, with a wait of 2-4 weeks. I paid 64 cents, so I got a couple of them. I put a zip tie through the bolt to avoid this in the future.
Quote from: Mike Qube on September 14, 2009, 11:47:37 AM
Nice find.
You should post the info in the replacement parts thread.
Mike Qube
Quote from: ducpainter on September 14, 2009, 03:28:33 PM
Nice find.
Just posted!
If anything else decides to fall off the bike, I'll post if the have those also. The place seems to have everything that could be needed when it comes to metric.
