Which hose connects directly to the pressure regulator?
Started by scription, September 16, 2009, 06:34:13 PM
scription
Hi all, first post!
I got my tank painted on my '02 Monster, but I'm not confident in my labeling of the hoses that connect to the tank. Is it the 'delivery' hose that connects directly to the pressure regulator, or the 'return/backflow' hose? (One hose connects to the pressure regulator, while the other connects to an injector.)
Thanks very much!
David
herm
hey david,  i thought i had a schematic around somewhere that would help..........but cant find it.
you might try moving your post over to tech for a better response.
No more Monster.
scription
Thanks for your reply!
I finally figured it out based on a 2004 repair manual - the delivery hose goes directly to the fuel injector, while the return/backflow hose connects directly to the pressure regulator. (If you're sitting on the bike, the delivery spout/nipple on the underside of the tank is the one closest to you, with the return spout directly above it.)
Hope that helps someone in the future...
