April 28, 2024, 04:06:15 PM
DFWM
Ceramic Coating
5
Topic: Ceramic Coating (Read 8763 times)
Re: Ceramic Coating
Reply #30 on:
June 10, 2008, 07:53:08 AM »
Quote from: GeorgeInDallas on June 07, 2008, 06:20:42 AM
I believe the tape will contain far more heat in the pipes than the ceramic coating,
You can do it yourself in a half day,
It's cheaper than ceramic coating,
Surprisingly big jump in performance,
On my bike, it can't be seen anyway (it's not particulary pretty).
The last thing you want to do is "contain" the heat from your pipes.
Ceramic coating (actually
aluminum-ceramic
distributes
the heat so that it is evenly shed. Wrapping your pipes makes hotspots on the pipes even more contained. It is like putting on a wool parka when you have a 108 fever. Wrapping the pipe with a hotspot will contain -- and cause premature failure of the pipe.
Wrapping in
car
racing is to reduce
engine compartment heat
. Simply explained, it causes horsepower gains because of the lowered heat in the engine, NOT because the heat is contained. This is not an issue with motorcycles, where the pipes are exposed to airflow.
Furthermore, wrapping a pipe
holds moisture against the pipe
. Stainless pipes WILL RUST over time and wrapping them just speeds this up.
You claim a jump in performance, I would like to see that on a dyno. Plenty of evidence to the contrary (i.e. no difference). All of the claims of hp gains seem to be from places selling the stuff.
Lastly, the proof is in the pudding: if wrapping pipes created a performance increase, why don't motogp and SBK teams wrap the pipes? (They are all aluma-ceramic coated or not at all).
Alu-ceramic coatings evenly distribute heat so it sheds faster
Alu-ceramic coatings prevent rust, since aluminum and ceramic can't rust
Alu-ceramic does not hold moisture like wrappings
Alu-ceramic will make your pipes last 100x as long (and can be re-coated when the coating wears)
I have a set of Sil headers on my 900SS which I bought in 1999 ( a 95 900ss) and got them coated. they still look NEW (use 000 wool and chrome polish to clean -- good as new).
Last Edit: June 10, 2008, 07:57:51 AM by ducatizzzz
GeorgeInDallas
Re: Ceramic Coating
Reply #31 on:
June 10, 2008, 02:52:44 PM »
I like the wrapping. The bike feels stronger, but you are correct, Truth in Advertising requires a dyno test. I wasn't expecting any performance change, but as I said, I'm surprised. Try wrapping yours and see what you think - it's only about $25. I ride my bike everyday, so I'm not terribly concerned about moisture accumulating. But I'm also happy for you that your pipes look nice...nobody can even see mine.
The principal reason I wrapped my pipes was to keep the @#$%@ heat from barbecuing my right thigh again this summer here in Dallas (where we invented Global Warming). It's doing a fine job, better I'm sure that ceramic could do, based on what you've said. I'm not interested in "spreading out the heat dissapation on the pipe"... I want the friggen heat to stay in the pipe until it gets past me, preferably out the tailpipe. Why on earth would anyone want to spread out the heat in the pipe?
Why don't they use wrapping in MotoGP? Gee, I guess that, at 200 mph, they probably don't get much heat on their thighs. Or maybe they just haven't caught up to us yet.
"It's about the ride.", Peter Fonda in Wild Hogs.
Re: Ceramic Coating
Reply #32 on:
June 10, 2008, 03:14:05 PM »
Quote from: GeorgeInDallas on June 10, 2008, 02:52:44 PM
You've hit on the only good reason for wrapping the pipe -- insulating against heat.
As far as dissipation, the overall amount of heat (in BTUs) is the SAME. If your bike produces 5000 btu's of heat, it's going to do it regardless if you have ceramic or wrapped pipes.
However, hotspots can and do occur and will compromise the metal of your pipes.. Ceramic prevents this, but wrapping does not.
However, ceramic does not make a good insulator -- it just makes the hotspots go away. Wrapping doesn't.
Duc L'Smart
Re: Ceramic Coating
Reply #33 on:
June 10, 2008, 03:15:46 PM »
Quote from: ducatizzzz on June 10, 2008, 03:14:05 PM
Can you re-word that in Haiku form?
'07 1098s, '06 Paul Smart LE, '99 BMW K1200RS,
'73 BMW R75/5
'67 Ducati Monza 250 Bevel Drive
'63 Vespa GS 160
Ducatiloo
Re: Ceramic Coating
Reply #34 on:
June 10, 2008, 03:28:37 PM »
Protect from the heat
Wrapping the pipe works very good
Hotspots will not leave
750 SS 01
800 S2R 05 Aprilia RST 1000 futura
Re: Ceramic Coating
Reply #35 on:
June 10, 2008, 03:35:47 PM »
Quote from: Duc L'Smart on June 10, 2008, 03:15:46 PM
I wish I could, wait till I drink more soju.
dallas2r
Re: Ceramic Coating
Reply #36 on:
June 10, 2008, 03:51:49 PM »
Quote from: Ducatiloo on June 10, 2008, 03:28:37 PM
Wrapping the pipe works very good <-----
syllable violation
2007 Monster S2R1000
2016 Multistrada 1200S Touring/Urban
A motorcycle will get you through times of no money better than money will get you through times of no motorcycle. -Unknown
Ducatiloo
Re: Ceramic Coating
Reply #37 on:
June 10, 2008, 06:53:42 PM »
Quote from: dallas2r on June 10, 2008, 03:51:49 PM
syllable violation
Wrapping the pipe works super.
Hot spots will not leave
Thank you for the correction it means a lot to me
Last Edit: June 10, 2008, 06:55:42 PM by Ducatiloo
750 SS 01
dallas2r
Re: Ceramic Coating
Reply #38 on:
June 10, 2008, 07:08:38 PM »
Quote from: Ducatiloo on June 10, 2008, 06:53:42 PM
All in a days work.
cdc
my superbike. nutts someone copied my avatar.
Re: Ceramic Coating
Reply #39 on:
June 11, 2008, 12:15:15 AM »
...I wrapped my pipes was to keep the @#$%@ heat from barbecuing my right thigh again this summer here in Dallas (where we invented Global Warming).
I have an ST4S and have not had a problem with heat as I would on superbikes with underseat exhaust when the pipes come up infront of the rear wheel along the thighs. I am curious why your ST3 emits heat there when our pipes are essentially low mounted.
cdc
GeorgeInDallas
Re: Ceramic Coating
Reply #40 on:
June 11, 2008, 03:40:26 AM »
It hasn't been excruciatingly hot yet... maybe I've misdiagnosed... maybe it's the radiator. Shall I try wrapping the radiator? I could probably contain the heat there, too. I'm just full of great ideas.
Duc L'Smart
Re: Ceramic Coating
Reply #41 on:
June 11, 2008, 05:07:46 AM »
Quote from: ducatizzzz on June 10, 2008, 03:35:47 PM
How's the drinking coming along?!?
Nice to see some "outsiders" lurking in our humble area
'73 BMW R75/5
'63 Vespa GS 160
cdc
Re: Ceramic Coating
Reply #42 on:
June 11, 2008, 09:51:14 AM »
Quote from: GeorgeInDallas on June 11, 2008, 03:40:26 AM
Well you know, it is called a radiator. so it must radiate heat. and you don't want heat so you could coat it instead.
cdc
Ducatiloo
Re: Ceramic Coating
Reply #43 on:
June 11, 2008, 09:53:16 AM »
Quote from: cdc on June 11, 2008, 09:51:14 AM
cdc
Your tires make heat at well....
750 SS 01
cdc
Re: Ceramic Coating
Reply #44 on:
June 11, 2008, 11:36:48 AM »
Quote from: Ducatiloo on June 11, 2008, 09:53:16 AM
Dang, we could coat that too! It'd look trick but...
cdc
5
